Hey guys. I have a Marshall Valvestate 232 solid state combo with a spring reverb tank. Ever since I got it (used) the reverb hasn't worked. So, I'm on a mission to fix it.
When I turn up the reverb knob, and shake the amp a bit, I can hear a bit of reverb (at least the springs moving around). So obviously the output of the tank is working. So I'm assuming no signal is going into the input transducer. Right? The first thing I did was take it out and clean all of the contacts. But, still the same result.
Any Ideas what it could be?
Spring Reverb problem.
Re: Spring Reverb problem.
Open the tank and make sure that the springs are connected to both ends inside.
Mike LX-R wrote:Open the tank and make sure that the springs are connected to both ends inside.
Already checked that as well. Everything appears to be connected.
Did you try new rca cables?
Mike LX-R wrote:Did you try new rca cables?
Not yet. I guess that will be my next step!
Any other foreseeable problems, if the RCA cables aren't the issue?
This is where I check out. I'm out of ideas.
I'm surprised someone else hasn't popped in.... GAB? You awake?
I just took the amp out of the chassis, and cleaned and tested my RCA cables. They have full continuity. So, I'm assuming the cables aren't the issue.
