You only want to fix one side, it really doesn't matter. You will see it less if you fix the back. Also, if you don't have coffee filters and you do have rice paper, silk or rolling papers... After the glue dries, you can paint it black with a sharpie, let it dry then put a little bit of Elmer's glue on the paper to strengthen it.
Got some rice paper, parchment and some other artisanal paper. I think I'll cut a 1/2" circle of rice paper and Elmers glue it on the rear, let dry and sharpie than, add a final coat of glue. Good to go!! Thanks for the help!!!!
