Fixing a screwdriver hole in a speaker
So, I punched a small hole in my Greenie, while mounting it in a 112 cab. :cry:
I was planning on sealing it with some weather stripping goo that you use on cars. Better ideas will be appreciated!
BroSlinger
Re: Fixing a screwdriver hole in a speaker
Post by BroSlinger »
if it's like a quarter inch hole, use layers of tissue paper + elmer's glue mixed with water.
I've used this method with great success.
Yup, small hole the diameter of a phillips head screwdriver - just under 1/4".
Elmers Glue cut with water and tissue paper... sounds good! :thu:
Ry Manchu
Post by Ry Manchu »
Coffee filter, cut piece just bigger than the hole. Glue with rubber cement or Elmer's.
A - A
Coffee filter... sounds like a plan! Cheers!
Ry Manchu
Post by Ry Manchu »
ajaxlepinski wrote:Coffee filter... sounds like a plan! Cheers!
The less glue the better.
A - A
Repair from front or back?
Ry Manchu
Post by Ry Manchu »
You only want to fix one side, it really doesn't matter. You will see it less if you fix the back. Also, if you don't have coffee filters and you do have rice paper, silk or rolling papers... After the glue dries, you can paint it black with a sharpie, let it dry then put a little bit of Elmer's glue on the paper to strengthen it.
A - A
Got some rice paper, parchment and some other artisanal paper.
I think I'll cut a 1/2" circle of rice paper and Elmers glue it on the rear, let dry and sharpie than, add a final coat of glue.
Good to go!! Thanks for the help!!!! :rawk:
mortatone
Post by mortatone »
Clear fingernail polish woks too, and comes with a handy little brush.
Alternatively, I suppose I could punch a few more holes in it and play some Link Wray! :lol:
soulsurfer
Post by soulsurfer »
Kinks'd
Winner of the 'Super Fuzz' in Ajax' 10k contest
Leather strap and some picks.
bottle o'bourbon and your daughter's panties
Pepi
Post by Pepi »
Cut it around 2 inches and then you have a free Fuzz Tone
BroSlinger
IMO, don't sharpy it.
You're just risking hurting the repair you've already done by making it wet and adding solvent.
leave it white.
BTW, coffee filters are relatively thick. Definitely wouldn't be my first choice.
rolling paper is a good suggestion if you don't have tissue paper.
Ry Manchu
Post by Ry Manchu »
The thinner the coffee filter paper the better, for sure. I wouldn't use the cone shaped coffee filters, some of them are too thick.
A - A
Thanks for all the tips - you guys ROCK!!!! :rawk:
Now, I just gotta put it in the work queue. :lol:
Walt
Post by Walt »
A bit of a Zig-zag + super glue works too. :thu:
that lets the sound right out boo
EugeneTheJeep
Post by EugeneTheJeep »
Link Wray used to poke holes in his speakers to get a ratty tone
I love Jeeps, Krav Maga, Thai Boxing and obviously Guitars.
House of Never
The Mighty Renegades
Modded my 50w EVH to fix green/blue volume jump
soulsurfer
EugeneTheJeep wrote:Link Wray used to poke holes in his speakers to get a ratty tone
is that like ratatouille?
