My friend has a VERY noisy CryBaby wah - when engaged it has slightly increased hum but a LOT of whooshy noise that modulates with the pedal's motion. Way more than normal.
Looking at the schematic, I'm suspecting the bypass cap before the input buffer is no longer shunting HF noises to ground (whoosh) or the bufffer or filter stage transistors are bad.
Unfortunately my little Tek scope is dead, and I am now without an o'scope.
Any other suggestions for common wah problems ?
A noisy CryBaby wah - where to start ?
- Reverse Entropy
“Never attribute to malice that which can be adequately explained by stupidity."(Hanlon's Razor)
"rock enough that I don't drown in ... jazz ennui" - draelyc
"...you realize that absolutely nothing happens when you get butthurt, right?
You know you're not going to go home and immediately have cancer, right?" - Steinmetzify
Re: A noisy CryBaby wah - where to start ?
Before any mods.... How is he powering it? Try it with a battery and see if it changes. Also, open it up and clean the pot and wah thread. I've seen a lot of Cry Babies with "issues" that were due to the inductor being too close to the power source or just dirty components..
