It's true in math AND audio. How many Klipsch speakers can you have? "All of them" appears to be the correct answer. I calibrated subwoofer #2 over the weekend using the automated Denon Audyssey XT32 setup routine. So, the modified full complement is: front: RP280, Surround Side: R-610F, Surround Rear: R-26F, Center: RP-440C, (Front) Subwoofer: R-112SW, (Rear) Subwoofer: R-10SWi (wireless).
The Denon 6300H will do 11.2, so there's still room for more. The room layout isn't ideal for a Dolby Atmos setup, but I could bi-amp the front and add a second pair of RP280's...
7.2 > 7.1
Re: 7.2 > 7.1
I was going to ask if you were going for an Atmos setup. I'm eyeballing a pair of SVS PB-16 Ultra for my next system.
What are your thoughts on dual subs vs just having 1?
Re: 7.2 > 7.1
linthat22 wrote:I was going to ask if you were going for an Atmos setup. I'm eyeballing a pair of SVS PB-16 Ultra for my next system.
Honestly? For my room, it's overkill. Especially since the primary sub is powerful. It just happens that I have a corner in the back that really couldn't be used for much, so I'm not giving up any space to do it. It's subtle, but I also like that not all of the low end is coming at me head-on. Sure, bass is "non-directional", but you can tell a difference and it seems to fill out the room a little more.
An Atmos setup would be cool, but I don't want to go to the trouble to run additional in-wall wiring. My room is small, too, so 7.2 is plenty. It's still tempting to use a couple of spare channels and bi-amp the front. More for 2-channel audio than anything else...
It smells like........Victory
