newholland wrote:that sounds loverly and the test driver is definitely killin' it.
but i gotta ask... what in the hell are all the knobs for?! i can't even imagine balancing that much data without imminent head assplosion...
What?
Only 14 knobs and 9 switches not counting Power and Standby
Basically 2 channels:
Channel 1Gain, Treble, Middle, Bass, Master
3-way Gain Style switch and 3 - Way Bright Swith
Channel 2:Gain 1, Gain 2, Treble, Middle, Bass, Master, Solo
3- way gain structure, 3- way Bright Switch under each gain, 3-Way Gain Style switch under both the Master and Solo
So, basically although you have a shared tonestack for channel 2, you can have different volume and gain settings when you kick in for solos.
Global SettingsPresence, Punch (Depth), and Hi/Lo power on the back
3-way Dark switch on the presence, 3-way voicing on the punch, and the hi/ow lets you choose between 460v or 540v voltage
DC Heaters, Teflon Coated Wire, 2 button footswitch, and Metro Zero-loss effects loop
