Resetup my shit.
GAS KING
Resetup my shit.
Post by GAS KING »
Fuck using my BFSR for the heavy.
Went back to a hybrid version of my initial rig idea.
Agile 3100 LP
Mojotone JTM45 clone
Vox 2x12 with emi wizard and tonker (high efficiency)
Pedalboard: Old POG>DOD fx17>Mesa BottleRocket>Zvex SHO>Tortuga Martini>Ibanez DE7>TU2
Initially, I had issues with the Mesa pedal being noisy. Replaced the tubes and got an official power supply. Seems to be okay now. Go figure.
SHO for a solo boost.
Pickup positions for various tones from distortion to muffy fuzz.
If I had a bigger pedal board. I'd definitely have a boost/OD, and replace the DE7 with a headrush.
Pretty much variations on the same theme.
With the laney aor100 coming in, this will all probably change. :facepalm:
Re: Resetup my shit.
Post by Elessar [Sly] »
Very nice! And good choice on the Laney ;)
Any clips of said rig?
lol
cibyl
Post by cibyl »
wat?
GAS KING
Post by GAS KING »
No clips of the rig. my recording set up isn't up and running, and this setup is subject to change constantly.
GAS KING
Post by GAS KING »
I suppose if you don't know the history, this sounds like a gear diary. :D
It sounds like joshuatsp faggogtry :D
GAS KING
Post by GAS KING »
I would have used that rig this entire time, had I hadn't had issues with the Mesa pedal being noisy (more like BUUBUUBUZZZZZUUZUZUZZZZZ).
It's the perfect combination of thick distortion with a fuzz character.
gb74
Post by gb74 »
Laney is going to change the whole thing... that amp has all the gain and tone you need so it should be a lot easier
GAS KING
Post by GAS KING »
guitarbilly wrote:Laney is going to change the whole thing... that amp has all the gain and tone you need so it should be a lot easier
That's what I'm hoping for.
Although, I have no clue. I had the 30w combo for a while, but it didn't get much use.
The seller said it's in good working condition, but who knows how old the tubes are, or if it needs a good cleaning.
I won't be taking something I don't trust to gigs.
Clearing up some board space for other cool things will be nice. The POG and Mesa take up 1/2 of my board. :-q
I really need the solo boost. Do you think I'll have to run that in the loop? or will the SHO out front work?
gb74
Post by gb74 »
out front if you need a gain boost
through the loop if you need an actual volume boost
it will work either way.
GAS KING
Post by GAS KING »
Hmmm. I hate using the loop. 2 extra cables.
GAS KING
Post by GAS KING »
Ooo.... http://www.talkbass.com/forum/f36/how-u ... st12917467
It is pretty dark.
I've used it with success as a bass preamp in the past!
Opening up the treble on this pedal would be GREAT.
sometimes i have to stop and remember that some people use pedals to get the right tone from their amp and not just to make crazy space noises. weird.
Y0UNGBL00D wrote:sometimes i have to stop and remember that some people use pedals to get the right tone from their amp and not just to make crazy space noises. weird.
You need a good fuzz.
Cirrus
Post by Cirrus »
Hugh Jaynus wrote:Hmmm. I hate using the loop. 2 extra cables.
Do what I did at the weekend; take three cables of equal length, colour code each end then tape them together with electrical tape. Treat as one cable from that point on.
GAS KING
Post by GAS KING »
Yeah, that's what I was doing when I was using the TOL100, but that was a 3 cable bundle (lead, FX Loop in/out) and 2 cable bundle for the footswitch.
pita.
....but I suppose. If that's what I have to do to make it work.
gb74
Post by gb74 »
I know. It's a lot. Life is hard.
GAS KING
Post by GAS KING »
i have one. im saying people needing the pedals for their amp to sound good. sucks. all my pedals are for sound effects, including fuzz. the clean and gain tones by themselves are pedal free. i dig that. i dont need a boost,comp, od, etc. to get the gain tone i like. i have a boost in the loop for loudness during solos, but thats it. not necessary at all.
GAS KING
Post by GAS KING »
Well, with a single channel amp, and the need for high gain............the only practical choice are pedals.
Cirrus
Post by Cirrus »
I like pedals for tone into a decent clean amp, it's just different to amp gainz. Sometimes one wins, sometimes the other.
Gotcha. I do all of the above.
GAS KING
Post by GAS KING »
The TOL100 is the only multi-channel amp that I've found with a truly wonderful clean channel. So good, that it could be used as a single channel amp.
Others I've tried just don't sound very lively. Useable, no doubt, but lackluster.
Some had good clean channels, but then their dirt channels are worthless.
cibyl
Post by cibyl »
Hugh Jaynus wrote:The TOL100 is the only multi-channel amp that I've found with a truly wonderful clean channel. So good, that it could be used as a single channel amp.
Wat?
