The Jettenuator ...
Re: The Jettenuator ...
Wow, thanks for sharing! :thu:
Loop Bizkit
Post by Loop Bizkit »
Have one here for eval. Should be able to check it out pretty soon.
cool 'bout time these things have an XLR , so question , since it's "good to up to 100 watts" Marshalls and many other amps go beyond that even though they are called "100" watters do you think the amp will be protected when cranked and running for a while or will they let out the magic smoke ?
fretless wrote:cool 'bout time these things have an XLR , so question , since it's "good to up to 100 watts" Marshalls and many other amps go beyond that even though they are called "100" watters do you think the amp will be protected when cranked and running for a while or will they let out the magic smoke ?
Soldano touches on that in the vid - he said he built a good bit of a 'safety net' in to it so you could run full tilt all day. Said a 100 watt Marshall tops out wattage-wise around 4-5 on the knob then just saturates from there :idk:
It does seem like a really neat lil box. I wonder if you can daisy chain cabs off that speaker jack
THE Soldano! :bow:
I missed that , must go back and watch again ... what is the $ ? I could use it . I had a Palmer years ago and and sold it after I let go of that rig , That thing sounded darn good . I do have a Dr Z airbrake which is good for knocking off some dB's but I could use that one with a DI fo sho
Mark Starr
Post by Mark Starr »
Cool video. :)
He said it's only rated for 100 watts, so I wonder if a cranked 100 watt head might stress it's operating parameters. Soldano seemed to gloss over that when he was asked about it in the video, or just my perception of it lol.
Mark Starr
That didn't really answer the question though or is it me :facepalm: , regardless of what setting the volume is at can it handle the spike above 100 watts when the power section is pushed. He seemed to deflect that.
OverDriven
Post by OverDriven »
I kind of doubt anyone would design an attenuator that wouldn't handle pretty much and 100 or 120 watt 4xEL34 or 6L6 type amp. Those are the very amps people usually buy attenuators for.
gb74
Post by gb74 »
How it did not answer the question? He says it's safe for 100w amps. He, out of everybody, knows that 100w amps can spike well above 100w. He still said it's safe for these amps.
Mark Starr
guitarbilly wrote:How it did not answer the question? He says it's safe for 100w amps. He, out of everybody, knows that 100w amps can spike well above 100w. He still said it's safe for these amps.
I guess I was hoping he would have gone into more detal about it, dunno. The TK guy at one point eluded to the scenario of a spike above 100 watts and then the conversation shifted to the volume knob after 4 the power section just saturates it threw me off. :facepalm:
GAS KING
Post by GAS KING »
Buys loud tube amp
Attenuates it down to whisper quiet volumes.
What would it do with a kt88 Marshall? Something that's got a bit extra in the wattage department?
pretty sure the man knows what he is doing so I'm not going to worry . I like to knock a few dB off some amps . It helps with my wreck clone as it stays clean 'till loud as fuck . I also like the option of going direct to the board live or for recording . Probably needs some cab sim but still seems like a nice tool to have in the box. Especially if the price is right . IME though extreme settings can sound like ass and I've had better luck using a good drive pedal and little amp with a 57 so we'll see . Dan are you getting one ?
NaturalBornBoy
Post by NaturalBornBoy »
Loop wrote:Have one here for eval. Should be able to check it out pretty soon.
Please keep us posted with the results, Arend.
Also, if you have the time, can you maybe do a comparison with the Rivera Rock Crusher?
Mark Starr
fretless wrote:Dan are you getting one ?
For Dan?
:shake:
NaturalBornBoy
Not to mention the Friedman one will be like 4x the price of the Jet City one.
Mark Starr
LesPaul-Marshall wrote:Prolly not, i like raising hell when i play. Dude on RT said the Jettenuator will retail for $239 and be available sept. 1st.
Not a bad price!
i386
Post by i386 »
:shake:
One thing i noticed is the Jettenuator has resistors for a load unlike the Weber Mass which has a speaker motor.
If Mike Soldano puts his name on it thats prolly good enough for me. :thu:
Weber MASS has resistors AND a speaker motor.
Gibson Les Paul Traditional Pro
Fender Standard Stratocaster MIM
Tama 3555 Acoustic
Gear:
Kemper Profiler, JBL LSR308, Sennheiser HD 280 Pro, Focusrite Scarlett 6i6, Apple iMac, Garageband
DIY Soldano X88R clone and 50W rack poweramp -> TC Electronic G Major II -> BBE Sonic Maximizer 362 -> RANE PE 15 Parametric EQ -> DIY Soldano X88R clone and 50W rack poweramp -> DIY 1x12 Cab
Fucks:
i386
Post by i386 »
BTW I ordered an attenuator last week. It has no line outs or speaker motor, but it does have some tone caps to put back some of the lost high freqs. Only $75. Can't wait to try it out!
Tama 3555 Acoustic
Gear:
Fucks:
colejustesen
Post by colejustesen »
That is sweet! I will be looking to get one of those!
Nateispro
Post by Nateispro »
damn that would make D.I recording so damn easy!!! :love: :love: I really want, i've read that it's going to be released September 1st
EDIT: just noticed that the release date was already posted... i'm a tard
Kiesel DC800
Ibanez RGD 7 Iron Label
79 Ibanez St-50
80 Ibanez Destroyer II
Kemper
draelyc
Post by draelyc »
fretless wrote:pretty sure the man knows what he is doing so I'm not going to worry . I like to knock a few dB off some amps . It helps with my wreck clone as it stays clean 'till loud as fuck . I also like the option of going direct to the board live or for recording . Probably needs some cab sim but still seems like a nice tool to have in the box. Especially if the price is right . IME though extreme settings can sound like ass and I've had better luck using a good drive pedal and little amp with a 57 so we'll see . Dan are you getting one ?
I just picked up one of these new for $175:
That's the "home" version; they make a PA/'live" version with an XLR out. They also make a fancy, nearly $600 version:
The one I got works GREAT with my Plexi Reissue (50 watt, though), especially for silent, direct-to-board recording late at night. :thu:
Just sayin'. :)
_______
MY REVERBNATION PAGE!
Captain Biscuit
Post by Captain Biscuit »
To be honest I'm not a fan of attenuators, I think they're oversold and pretty specialist. When you combine them with good cab emulation, that's when it gets interesting.
Variable-sensitivity speakers like the Eminence Reignmaker (or Fluxtone if you have a million billion pounds to spare) seem like a much more sensible way to get those bulbs glowing without blowing too many eardrums.
Nateispro
Post by Nateispro »
Just sayin'. :)
What do you think of it so far? I would love to have something to let me direct record into my board, hows the emulation sound?
Kiesel DC800
79 Ibanez St-50
Kemper
