Spring Reverb problem.
Posted: Thu Oct 16, 2014 10:43 am
Hey guys. I have a Marshall Valvestate 232 solid state combo with a spring reverb tank. Ever since I got it (used) the reverb hasn't worked. So, I'm on a mission to fix it.
When I turn up the reverb knob, and shake the amp a bit, I can hear a bit of reverb (at least the springs moving around). So obviously the output of the tank is working. So I'm assuming no signal is going into the input transducer. Right? The first thing I did was take it out and clean all of the contacts. But, still the same result.
Any Ideas what it could be?
