Yamaha THR question
butterguitar
Yamaha THR question
Post by butterguitar »
Since the THR has been a topic of discussion, I have a question.
I got my THR5 earlier this week and it's a GREAT sounding amp! Killer effects and overdrive and great tone for such a little amp.
My question is: Is it normal for the amp's speakers to break up after hitting the 3 o clock part of the volume knob? When I turn up the volume, (and with my "master" at half), it gets this weird breakup sound that I don't like. So I have to turn down the "master" in order for it to sound better at low volumes. Kind of sucks that I can't have them both high up, in order to get max volume when needed.
At first I scared myself because I hooked up to my ipod into the amp on full blast (accident) and thought I did damage to the speakers. L-)
Gear List:
Guitars
2012 EVH Wolfgang Special
LTD George Lynch Burnt Tiger
2014 Fender Telecaster Special
Charvel SD2
Amps & effects
EVH 5150 III 50 watt w/matching 2x12
Marshall DSL40C
Atomic Amplifire AA3
Re: Yamaha THR question
I have the THR10, not the 5, but I run the master dimed or nearly dimed for all of the amp models - they all just sound much better that way. You should be able to crank the master and just use the volume control to control the overall output.
The cab itself will rattle if you crank the volume too high on my THR10 - but theres really no point in playing it that loudly, so I don't.
That may be what you are talking about - cab rattle, not speaker breakup.
Pepi
Post by Pepi »
Could not use at Woodstock
butterguitar
Pepi wrote:Could not use at Woodstock
Your avatar......... /:)
Devin wrote:I have the THR10, not the 5, but I run the master dimed or nearly dimed for all of the amp models - they all just sound much better that way. You should be able to crank the master and just use the volume control to control the overall output.
Ahhh!!!! Didn't even think about cab rattle, that must be it!
Gear List:
Guitars
Charvel SD2
Amps & effects
Marshall DSL40C
