I come here for the Technical data ...
Re: I come here for the Technical data ...
we had a few 440hz hits in the navy (fleetwide, not on my ship that i can recall). no fun. notice the frequency, not the potential, kiddies
- TurboPablo
You got attacked by low midzzz?
That's brewtul.
That's brewtul.
- elder_things
Shockwave wrote:The voltage isn't what kills you its the current, usually you won't die from just a voltage hit, but if theres any draw on it all it takes is .1 amps really to kill you
Very high voltage and current through a body will cause physical trauma where as around .1 to .2 amps of current through your heart can cause potentially fatal arrythmias.
Kind of a stupid saying though.
true. burns vs heart stops or current-induced clenching, ill take neither please.
Safe isolation tbh.
Been an electrician for five years, not been zapped once.
Though the day surely cometh ¬_¬
LesPaul-Marshall wrote:Been bit by 115 & 230 a few, did Okay. One of the worst bites was replacing a 4 foot florescent bulb all sweaty & wet. I became part of the circuit. That shit hurt, was on a ladder. Wokeup that nite with chest pains ...![]()
How did you end up getting zapped like that? Were you in the rain or something
- TurboPablo
Dropsix wrote:LesPaul-Marshall wrote:Been bit by 115 & 230 a few, did Okay. One of the worst bites was replacing a 4 foot florescent bulb all sweaty & wet. I became part of the circuit. That shit hurt, was on a ladder. Wokeup that nite with chest pains ...![]()
He was sweaty. It danced all over him. Personally, i won't change Flos' while hot. Those ballasts put out a lot of voltage. It's like getting bit by a ignition coil. Which seriously fucking hurts.
LesPaul-Marshall wrote:Dropsix wrote:LesPaul-Marshall wrote:Been bit by 115 & 230 a few, did Okay. One of the worst bites was replacing a 4 foot florescent bulb all sweaty & wet. I became part of the circuit. That shit hurt, was on a ladder. Wokeup that nite with chest pains ...![]()
It was about 105 degrees in a hallway with no AC on a ladder, the fixture was older and i couldn't line up the pins in the sockets right so i had fingers of each hand on either end of the 4 foot bulb trying to guide the pins in the socket all sweaty an voila ! I completed the circuit, the current ran from hand to hand across my chest ... not good. Voltage in a floruecent light is amplified, much more than 115v.
Also, changing lamps when hot shouldn't be a problem if you isolate the circuit
