Ah ok. I've heard high gain Hot Rod 25 Crunch demos sound pretty close, but not exactly, so I thought it was doable (just a voicing/gain change).
I've been told a couple times (from biased sources) the Decatone Crunch circuit is identical to the SLO-100 Crunch circuit. But when I played one years ago, there was a noticeable difference and I can hear that tone in Decatone Crunch demos online. I was told maybe the amp biasing(???) was the difference between the two. This just confuses me further.
My previously owned purple Decatone also had the very rare DeYoung transformer option, but it probably made no difference compared to a normal Decatone with the Mercury transformer. I bought mine years ago from a former Maryland Soldano dealer. The Crunch channel with the stock 4x12 with X-12000s was incredible, but I prefer the SLO so I sold it.
Looks like in the end I might mod my 100 LTD for a Decatone Crunch and pair it up with my SLO (first), use a Line6 Helix SLO model in the loop, or consider getting another 100 LTD with an SLO mod. Will see how it goes. I don't think I want to take my SLO out of the house, it's my #1 for life.
I like experimenting with high gain. I got an awesome fuzz tone, by running a Supercharger into a Decatone Crunch, and I'd like to hear SLO Overdrive and Decatone Crunch mixed "side-by-side" and one into the other for that fuzz tone. I also have a Hammond XK-3 keyboard organ with tube preamp overdrive that I'd like to run into them.
I'm definitely a Soldano fan and had a period of time where I could compare the SLO, Decatone, Reverb-O-Sonic, and Supercharger. Have never really had bad amp GAS since.
Eastwood: Trey Anastasio, Line 6: Helix Floor, HX Stomp, Novation: Launchkey Mini MkIII, DAW & Synths: Bitwig Studio
Yeah they're not identical, the differences are nothing major but they're there.
I have an 100 LTD stock that I like quite a bit. The thing about that amp is it's biased ice cold from the factory. Mine was biased at 7mA (!!!) per tube. That's below the point of crossover distortion. So changing it to around 30mA definitely helps it quite a bit. Made it punchier, clearer and fuller. But I do want to mod it with a depth pot and move the loop after the tone stack. The LTD has a lot of potential with just some minor tweaks.
Epic Amplification has made a "Deca-Crunch" mod for the 50/100 Crunch channel. Will report back when I eventually get it and the SLO Overdrive installed.
Mr_You wrote:Epic Amplification has made a "Deca-Crunch" mod for the 50/100 Crunch channel. Will report back when I eventually get it and the SLO Overdrive installed.
That's cool. Bryce does good work. If anyone can do this, that's him. I am actually shipping my LTD out to be modded by him tomorrow.
- cliffenstein
I’m officially part of the club...JCA50H owner - LOVE it!!!!!
Are there any mods by where the footswitch doesn’t need to be plugged in to play through the crunch channel?
GUITARS
1988 Fender MIJ ST54 Hardtail Stratocaster w/SD JB Jr
2011 Recording King RD-126
2012 Gibson Les Paul Traditional Mahogany
2015 Fender Road Worn '50s Stratocaster
2018 Gibson Limited Edition Les Paul Junior
2019 Gibson Original Collection Les Paul Special
AMPS
1979 Marshall JMP 2204
1997 Marshall JCM 2000 DSL100
2021 Epic Amplification AR50
2022 Jet City Custom JCA800
2022 Mojotone British 800 2204
CABS
Marshall JCM 800 1960A
Marshall 1936 Lead (all birch build)
Marshall 1936 Vintage (all birch build)
SPEAKERS
Celestion G12T75 (original white label - vented)
Celestion Heritage G12-65
Celestion UK built Vintage 30 (T4416B)
BANDS
https://facebook.com/huntingtonsusa
https://facebook.com/thestivs
https://facebook.com/jonniwalkerandthesatisfaction
AMPS
CABS
SPEAKERS
BANDS
- Tortuga
cliffenstein wrote:I’m officially part of the club...JCA50H owner - LOVE it!!!!!
Welcome!
I set up a reference on the first 3 postings of this thread (page 1), but see that my links have stopped working... Must be the forum domain change. I'll have to fix those...
Anywho, here's the link to that mod - viewtopic.php?f=53&t=3424&p=59941#p59941
- Bassman overhaul - G-MAN
The easiest way is to get a 1/4" plug, remove the cover and solder the 2 tabs together. Then just leave it permanently plugged into the back of the amp. It's what I do when I'm only using the crunch channel.
- cliffenstein
GuitarBilly wrote:cliffenstein wrote:I’m officially part of the club...JCA50H owner - LOVE it!!!!!
That’s the ticket...thank you!!!!
GUITARS
AMPS
CABS
SPEAKERS
BANDS
AMPS
CABS
SPEAKERS
BANDS
- Mamberg Jr
I wasn’t really digging the Amelia for a second, but all I had to do was turn the volume on my guitar to about 8. Magical
MusicMan Axis Super Sport semi-hollow
Charvel Desolation Star
Squire Partscaster
Jet City Amelia
mamberg II
Squire Partscaster
Jet City Amelia
mamberg II
- BleedingWhiskey
cliffenstein wrote:GuitarBilly wrote:cliffenstein wrote:I’m officially part of the club...JCA50H owner - LOVE it!!!!!
I used to do the exact same thing, but I kept losing or breaker the 1/4" jack. So this past weekend I installed this switch mod that was original posted by Jay (see link below). It's super simple and he even linked the parts you would need (switch and a shunt tip 1/4" jack), which are also pretty cheap. Like less than $5. I did, however, have to buy a metal tap drill bit, but that was only $20, so it wasn't to bad.
http://www.guitargearforum.com/forum/viewtopic.php?f=53&t=3424&p=59941#p59941
Stringy Things:
2003 Fender American Standard Stratocaster (SD PG/Dimarzio VVB pickups)
2019 Gibson Les Paul Standard 60's (SD PG humbuckers)
2021 Gibson Les Paul Classic (Dimarzio SD/36th Anni humbuckers)
2018 Gibson Les Paul Classic (Fralin P-90 pickups)
2017 Balaguer GAB Scumden (SD PG humbuckers)
2020 Fender American Professional II Telecaster (SD Broadcaster/Vintage tele pickups)
2011 Fender Blacktop Telecaster (GFS Surf 90 pickups)
2021 Jackson JS32 Dinky (SD JB/Jazz humbuckers)
2019 Fender Active Deluxe Precision Bass Special (stock pickups)
Loud Makers:
Jet City 100H LTD head amp
Jet City 50H head amp
Jet City USA Custom JCA48C 4x12 (V30s)
Jet City JCA5012C 1x12 combo amp (stock speaker)
Stompy Things:
Lots o' pedals
Line 6 Helix LT
THE VELOSTACKS
Loud Makers:
Stompy Things:
Lots o' pedals
Line 6 Helix LT
THE VELOSTACKS
BleedingWhiskey wrote:cliffenstein wrote:GuitarBilly wrote:cliffenstein wrote:I’m officially part of the club...JCA50H owner - LOVE it!!!!!
Yeah the switch is probably the better way to go. The plug is just easier.
You won't break the jack if you remove the plug cover and just use the actual plug. The way I have mine, it doesn't stick out of the headshell at all. You can also use a flat "pancake" plug.
- BleedingWhiskey
GuitarBilly wrote:BleedingWhiskey wrote:cliffenstein wrote:GuitarBilly wrote:cliffenstein wrote:I’m officially part of the club...JCA50H owner - LOVE it!!!!!
I was using the pancake style jacks, but I would either lose it or after a while the tab would break away from the barrel and it would stop working. I mean, it took almost 2 years for one to break, so losing it was more of an issue for me. I lost 4 of them over the 8 years I've played Jet City amps
Stringy Things:
Loud Makers:
Stompy Things:
Lots o' pedals
Line 6 Helix LT
THE VELOSTACKS
Loud Makers:
Stompy Things:
Lots o' pedals
Line 6 Helix LT
THE VELOSTACKS
I'm going to perform the elevated heater mod using twisted pair wiring soon because my JCA50H has ungodly hum going on. On that mylespaul forum thread, one guy did this replacing all the traces with the wire, and another guy who sent his amp to Jet City ended up with the same fix but only for v1-v3. It would seem that if this was determined to be good enough by the team at Jet City that it's probably good enough for me, but has anyone compared the results? Like has anybody done the v1-v3 and still had hum and found they still needed to do the whole shebang?
I don't want to do any more sitting around clipping traces than I have to, but if it's necessary to do them all I'd rather do it in one go.
- Tortuga
Bardagh wrote:I'm going to perform the elevated heater mod using twisted pair wiring soon because my JCA50H has ungodly hum going on. On that mylespaul forum thread, one guy did this replacing all the traces with the wire, and another guy who sent his amp to Jet City ended up with the same fix but only for v1-v3. It would seem that if this was determined to be good enough by the team at Jet City that it's probably good enough for me, but has anyone compared the results? Like has anybody done the v1-v3 and still had hum and found they still needed to do the whole shebang?
I did the elevated heater mod to all 5 of my 12ax7s by cutting the traces and wiring in twisted bell (solid core) wire. Honestly, I don't think it made a massive difference in the amount of hum/noise, and I wish I hadn't done it, as I feel that I've somewhat weakened the amp's integrity/reliability and probably wouldn't feel good selling it at this point.
There were a couple of postings about changing the heaters over to DC (see the list of links I posted in the first three of this thread on page 1), and I think that's probably got a lot more merit than doing the elevated heaters, especially if this is an amp that you intend to gig and/or sell.
Yeesh, that seems like something I wouldn't want to do if I was going to sell it, personally. Rigging up a PSU seems a lot more dubious to me than replacing traces with solid wire, even if it is more effective. Honestly, I paid $250 for this and if it's just gonna hum like this I'll probably hang onto it until I track down another amp or two in the next couple months, then sell it off for about what I paid.
On an unrelated note, the glass on one of the 6L6's totally and suddenly separated from the base of the tube earlier. Never had that happen before, but I had another matched pair to pop in and all SEEMS fine...
- Tortuga
Are you certain that the hum is all the amp? Do you have another amp you can plug into same outlet and put in same place to see if you're not getting interference from noisy circuits / lights / etc?
G-SPACE wrote:Are you certain that the hum is all the amp? Do you have another amp you can plug into same outlet and put in same place to see if you're not getting interference from noisy circuits / lights / etc?
I have plugged the amp into a few different circuits in my house it sounds the same all over. It's present on the Crunch channel too, but much lower. If you put the preamp all the way down and crank the volume you don't hear it on the Crunch, but as soon as you engage some preamp it's there, and it gets fairly audible at high volume levels with any decent amount preamp gain, but it is a fractional of the noise present on the OD channel. Strangely the hum/buzz doesn't come across nearly as loudly on a miked signal as it seem in the room. I think because it probably isn't actually all that loud compared to the actual sound of the amp - it's just such an annoying sound! It would make a good sound effect of someone being electrocuted in a cartoon or something.
- Tortuga
I was talking to an engineer some time ago about this, and he recommended getting a ferrite core to attach around the power cord. That's not something I'd heard before, but this guy knows his shit. They're used as noise suppressors for a lot of other stuff, so why not this???
I recommend giving one of these a try. They're cheap, super easy to install/remove, and might just take care of a lot of the issue.
This is what they look like. Just search "ferrite core" or "ferrite clamp-on core"
G-SPACE wrote:I was talking to an engineer some time ago about this, and he recommended getting a ferrite core to attach around the power cord. That's not something I'd heard before, but this guy knows his shit. They're used as noise suppressors for a lot of other stuff, so why not this???
Well yeah those are for suppressing EMI which is why you may see them on things like USB cables. I really don't think that's what is going on here, although I have a bunch of them in a box somewhere so I could try it for shits and giggles, but if it worked I would be very confused about how and why.
- Tortuga
Dude - try one out and PLEASE let us know if it makes any difference
What tubes are you using? This amp is very sensitive to tubes. I recently helped someone troubleshoot their amp and he found out that the amp was humming every time he put JJ's in any position.
I'd recommend Sovtek 5881 power tubes and a Sovtek LPS in the PI, with Chinese tubes in the other preamp positions.
It came with Ruby 6L6GC (now has another pair of the same) and all Chinese 12ax7. The ones in V1 and V2 are the "HG" ones selected for low noise etc.
I've swapped around all kinds of preamp tubes and I don't know that I can say it made any difference one way or another.
Well I hate to tell you this but putting a ferrite bead on the power cable does nothing. It really wouldn't have made sense if it did, so in a way I'm glad.
