- draelyc
ajaxlepinski wrote:Lack of personal style? Dude, you're the Sean Connery of GAB!![]()
_______
MY REVERBNATION PAGE!
Re: Sequencing drums in GarageBand?
- Ostinato Rubato
- draelyc
trey85stang2 wrote:you can do it, a midi keyboard will help, but you can do it all in the piano roll. Its tedious but can be done. I personally use an alesis sample pad pro, play the drum parts (the best I can) then fix my sloppy playing in piano roll
Dig. Thanks!
_______
- Marc G
RUBATO wrote:Step 1) post 5 drum sample comparison videos in the most confusing format you can manage.
what version are you using?
- draelyc
Marc G wrote:RUBATO wrote:Step 1) post 5 drum sample comparison videos in the most confusing format you can manage.
I can never remember off the top of my head, and I'm at the office now and can't look it up.
I R noobzors, lol.
_______
- Marc G
- draelyc
Marc G wrote:depending on your version there will be a Garageband Drummer you can insert, it will automate the drums for you and you should be able to export it to Midi and then apply a drum kit to it and THENNNN just modify it if need be... I know you can do that in Logic at least
Oh, man. :-/ So many steps...
I found the various drum kits that came with GB, and I've used them to make short clips/amp demos 'round here...
_______
- neilrocks25
This.
- neilrocks25
draelyc wrote:Marc G wrote:depending on your version there will be a Garageband Drummer you can insert, it will automate the drums for you and you should be able to export it to Midi and then apply a drum kit to it and THENNNN just modify it if need be... I know you can do that in Logic at least
- draelyc
Not really at a point where I can think about stepping up to a bigger, better DAW ~ and I've barely scratched the surface of GB so far, anyway.
Much appreesh, y'all!
_______
draelyc wrote:Not really at a point where I can think about stepping up to a bigger, better DAW ~ and I've barely scratched the surface of GB so far, anyway.
- draelyc
_______
draelyc wrote:...
www.groovemonkee.com
https://dunkysndemos.com
- draelyc
JerEvil wrote:GB will do exactly what you are asking. If you use the Drummer feature, use the kittle controller ball to get an approximation of what you want. Then you can always convert it to a midi track and adjust it from there if you want. For your needs I am sure the Dummer will be fine. Experiment with different "drummers" and kits.
http://www.groovemonkee.com
I haven't had a chance to try this yet, but I will ~ much appreciated, Jer!
_______
- Ostinato Rubato
I just watched some quick tutorials on how to do this in Garage Band. So I know how, but I’m not gonna tell you.
- draelyc
RUBATO wrote:I just watched some quick tutorials on how to do this in Garage Band. So I know how, but I’m not gonna tell you.
[video]https://youtu.be/Rzu6hdfZ2V4[/video]
_______
I use Garageband on my ipad for all my writing because of its ability to be quick and easy with drums.
Doesn't have most of the tools people want in a DAW but I use it for getting ideas laid down and clearly communicated. Doesn't need to be any better than it is.
So with that said what I always do is a combo of manually programming the kick and snare (and sometimes crashes if needed) and using the built in Drummers to handle everything else (fills, tom work, almost all the symbols).
Its easy to "program" the kick and snare on iPad because I just play out the rhythm for each part. Fix it where needed, then loop. After that add the drummer and usually have the drummer synced to the bass or rhythm guitar. Sometimes I sync it to the kick/snare part.
Anyway I write songs FAST this way and the software mostly stays out of my way which is why I like it. Someday soon I'll use a more serious DAW but I love the flow on the ipad with garageband for writing.
Maps:
Cabs:
Maps:
Cabs:
- itchyfingers
Of all the dead threads to be reincarnated... That or Drae has died and been reincarnated as a Chinese bot named MonikaLarkin.
Edit: Spellung is hardt
itchyfingers wrote:Of all the dead threads to be reincernated... That or Drae has died and been reincarnated as a Chinese bot named MonikaLarkin.
Wow, obviously I did not fucking notice.
Captain observant over here, I guess I always assume if its under active/view new posts its actually new and not some weird necro bot bump.
Maps:
Cabs:
Maps:
Cabs:
- Tortuga
Cmon, K - admit you got excited at the thought of a token female joining the fray
- Bassman overhaul - G-MAN
G-SPACE wrote:Cmon, K - admit you got excited at the thought of a token female joining the fray
Too old any married for that unfortunately.
Also
Maps:
Cabs:
Maps:
Cabs:
- itchyfingers
K-Bizzle wrote:itchyfingers wrote:Of all the dead threads to be reincernated... That or Drae has died and been reincarnated as a Chinese bot named MonikaLarkin.
Wasn't calling you out, KB I promise! The only reason I noticed is because I hadn't seen a Drae-which-minutiae-is-better thread in like a year.
