Quick clip
exafro
Quick clip
Post by exafro »
Was messing around last night with the 2 ch Recto and Uber models in Thermionik and decided to make a quick clip. How does this sound? Are the guitars too dark?
https://soundcloud.com/exafro/metal34
Steinmetzify
Re: Quick clip
Post by Steinmetzify »
Dude ain't nothing wrong with that at all. Would be interested to hear them a little brighter but this had me headbanging inside of 3 seconds as it was.
:rawk: :rawk: :rawk: :rawk: :rawk: :rawk:
Fragments of a sunbeam
glaring on a kitchen knife
Steinmetzify
Re: Quick clip
Bumping this for Ex
exafro
Re: Quick clip
Post by exafro »
Thanks for the listen Stein. I'm gonna tweak a bit and post a slightly different version tomorrow. I noticed the bass was a bit too loud in my car, which I didn't hear through my monitors and headphones.
Re: Quick clip
Sounds good. I'd try a little brighter but not much.
Great clip dude.
hiatus o
Re: Quick clip
Post by hiatus o »
Sounded right to me, sweet chuggy heavy goodness
exafro
Re: Quick clip
Post by exafro »
Quick update with a slightly tweaked version. This might be better, or worse, but its different lol
https://soundcloud.com/exafro/metal341
Re: Quick clip
Sounds pretty damn good to me! :rawk:
Steinmetzify
Re: Quick clip
Little bit more defined, dig this one more. Nice work mang
EDIT: mind busting out how you mixed this? This is a seriously great tone for as low as it is...
exafro
Re: Quick clip
Post by exafro »
Quad tracked guitars(1 track of Recto and Uber per side) The Uber is slightly dominant in the mix, but not by much, maybe 1 or 2db at most.
Recto chain:
Kazrog Vintage Driver
Gain 2.0
Tone 10
Volume 6.8
Duality 2ch
Orange - Modern
Gain 5.0
Bass 4.4
Mid 2.0
Treb 5.0
Pres 4.0
Depth(off)
Bright Swith off(Normal)
Silicon
Bold
Output -7.5
Saturation 5.0
Recabinet 5
Ownhammer OH412 ORN + DZL V30 (Heavy hitters pack, A1 pick subfolder)
High pass 100
Lo Pass 10k
Lo Mid -1.9 @ 300 hz
Output Volume -10 (I find Thermionik tends to clip the bus if the levels aren't brought down. I always cut volume in Recabinet, its just easier to always do it in one spot across as presets)
I bussed the Recto tracks together and then added some minor multiband compression and a Slate VTC New York( Console, Normal, Gain 1.0, Mix 100%)
Uber Chain
Vintage Driver, same settings as above.
Uber
Bass 3.0
Mid 6.0
Treb 6.0
Pres 1.6
Depth off
Bright off (Normal)
Output -7.6
Saturation 5.0
Recabinet 5
Ownhammer OH 412 MES V30 CUT-05
Same EQ section as Recto
Bussed the Uber tracks together again with minor multiband, no other processing.
exafro
Re: Quick clip
Post by exafro »
Forgot to mention. Guitar is cheapo Jackson import with an EMG81 in the bridge. Drop C tuning
Steinmetzify
Re: Quick clip
Thanks mang!
