Bast EQ plugin for guitar
BroSlinger
Re: Bast EQ plugin for guitar
Post by BroSlinger »
Focusrite Red2 EQ is pretty rad. It's a 4 band parametric with nice shelving capability. not free though, unless you got a coupon for buying a focusrite interface.
Tokyo Dawn Nova is a 4 band visual eq great for shaping everything. Free
Tokyo Dawn Slick EQ is a 3 band semi-parametric. nice for adding a bit of finishing. not for initial tone shaping though. free. I use it for mastering usually.
BroSlinger
Albert Ross wrote:
BroSlinger wrote:Focusrite Red2 EQ is pretty rad. It's a 4 band parametric with nice shelving capability. not free though, unless you got a coupon for buying a focusrite interface.
Am about to buy a Focusrite USB audio interface, so I'll check out the Red2.
the deal also included Red3 Compressor which is fire on bass, mang. bam! I love it for bass.
newholland
Post by newholland »
my fave is the waves api 550b, or the pultec eqp 1a.
BroSlinger
Albert Ross wrote:The Red2 Red3 bundle looks to be about 3 hondos... Any idea how much are they knocking off with that coupon?
The Waves API 550 looks to be very highly rated. It works OK with Reaper?
I got it for free when I bought my 2i2. :idk: :idk: :(
Maybe, the deal is off. It was a while ago. :(
get the free stuff I mentioned from Tokyo Dawn. They will knkock your socks off. Also, get their Kotelnikov comp. all free.
newholland
The waves stuff works great with reaper- all ive ever used em with :D
BroSlinger
Albert Ross wrote:
BroSlinger wrote:I got it for free when I bought my 2i2. :idk: :idk: :(
Really? That's the model I'm looking at.
I mean, if the promotion isn't going on, it's not going on. :(
BTW, I would HIGHLY recommend getting something with more ins and outs.
The 2i2 sufficed for about 2 songs, then I got an 18i20. It's not uncommon to need 6-8 inputs for a guitar track.
BroSlinger
Albert Ross wrote:
BroSlinger wrote:The 2i2 sufficed for about 2 songs, then I got an 18i20. It's not uncommon to need 6-8 inputs for a guitar track.
You mean for physical microphones?
maybe?
stereo pedal/amp setup = 2 mics.
want to use lofi mic for blending = 2 more mics
ambient room mic or 2 = 2 more mics.
maybe you're doing a direct signal for reamping or something. 2 more inputs
I'm just saying. 2 inputs will ruin your fun very quickly
Slate Digital Virtual Mix Rack
It's not parametric but, the Waves GEQ is really cool. Mono and Stereo, 32 band graphic EQ. It's on sale right now.
http://www.waves.com/plugins/geq-graphi ... r-overview
Waves can be annoying to download plug-ins. First, you have to download Waves Central onto your computer (easy peasy). Then you have to find the correct Installer to download and unzip. I have a Mac OS 10.8.5 (Mountain Lion) with ProTools 10. Had to ask Waves IT for help because, the don't make it easy to find the installer you need. When I downloaded the installer, I had to download a bundle of plug-ins and manually delete the ones I didn't pay for, before installing the ones I did pay for.
Their plug-ins rock but, installing them can be a pain in the ass.
I highly recommend the Waves Vocal Rider - it's better than a compressor for vocals.
Every once in a while, Waves sells their SSL E Channel Strip as a separate plug-in. Got it for $39 a few weeks ago: http://www.waves.com/plugins/ssl-e-channel
Albert Ross wrote:
MR RUBATO wrote:Slate Digital Virtual Mix Rack
Don't see an option to just get the FG-N (The Neve clone). So you have to get the bundle?
Yes you have to get the whole rack, but I don't think you'd be disappointed. You get A LOT of excellent components in the VMR.
newholland
Look up a download called solid 4010. Its an ssl 4000 eq and its free! Ive had some goid luck with quite a few freebies, for sure!
Same here, it was about two years ago when I got mine. I use the reverb plugin all the time. The redeq has a cool rhythm guitar preset which is pretty close to where I set my eq normally.
Lately I've been skipping the redeq and just using the hi and lo pass in Nadir.
Albert Ross wrote:
newholland wrote:Look up a download called solid 4010. Its an ssl 4000 eq and its free! Ive had some goid luck with quite a few freebies, for sure!
Checking that one out now.
Fat Fish wrote:Lately I've been skipping the redeq and just using the hi and lo pass in Nadir.
So I'm guessing you're dialing out errything below 50Hz and above 4Khz ?
I've seen those controls while using Nadir, but never messed with them.
To be honest I don't pay any attention to that. I just spin the dials until I get rid of any annoying sizzle or flubbiness. I did some recording over the weekend and in that instance, I just bumped each deal a bit beyond their default positions.
newholland
RIFF
Post by RIFF »
Ive tried only a few, but the one I like best is Ignite PTEQ-X. The only reason why is I try to do very minimal EQing & it seems Im getting results without it sounding colored.
Id like to try a plethora of plugins, but so far, it works fine.
newholland
No problem.
Also- this is my fave style of guit eq-. The api 550b-. This isnt an exact replica- but seems pretty close! http://www.vst4free.com/get_lpn1.php?wi ... 550_v2.zip
RIFF
Post by RIFF »
Albert Ross wrote:Thanks Dan :thu:
So the Ignite PTEQ-X is based on the Pultec EQ's? I downloaded it and will check it out tonight if I can.
What's the thinking on EQ ordering (EQ before cab, after CAB, before amp sim or after, etc).
And also, what about running more than one instance(or even multiple types) of an EQ plugin on the same track?
In the small amount of time I've played around with these EQ plugins, it does make a difference to my ears on the order you place them with your other VSTs.
Yeah, its Pulltec based.. let me know what you think once you try.
I usually mic a cab, so the eq is going after. But if youre using IR's, theres that option, just see what works for you!
exafro
Post by exafro »
The ReaEQ works great if you don't mind the generic interface. If you need to do a shit ton of EQ'ing to a guitar track, you're probably better off working on mic positioning and laying down another take.
BroSlinger
Albert Ross wrote:
exafro wrote:The ReaEQ works great if you don't mind the generic interface. If you need to do a shit ton of EQ'ing to a guitar track, you're probably better off working on mic positioning and laying down another take.
I spent some time working with the ReaEQ, and you're right. It's pretty comprehensive!
I ordered a new USB audio Interface from Whole Foods. It comes bundled with the Red EQ and compressors like BroSlinger told me about.
Excited to see what those plugins are like. :beavis:
I love the toans I'm getting just running my tube map into load box => audio interface => Reaper.
But when you get into it, you realize that if you're playing a distorted guitar toan and you use a lot of palm muting/heavy pick hand attack stuff you need to be able to notch out 140~150Hz or you're gonna get that boomy shit going on your tracks.
Wut? :confused: :confused: :confused:
