RF bleed-thru in new DAW
Re: RF bleed-thru in new DAW
tin hats for everything
seriously - Faraday cage
Faraday Cage - wikipedia
how practical it is to build on that works - :idk:
:rofl:
How's this?
or this?
I would plug straight into DAW , track w/ headphones and check playback for said C&W
you got lucky , the whole wiring in the place is like an antenna .
CptCyanide
Post by CptCyanide »
Albert Ross wrote:
mamberg wrote:seriously - Faraday cage
Mams, you are about as useless as a fuckin' white crayon.
I remember reading an article about Eric Valentine (recording engineer). He ended up building a Faraday cage to record high gain single coil guitars without hum!
Guitars
Les Paul Studio, CIJ '72 Thinline Tele, Fender TC-90, Ibanez RGA8
Amps
Laney VC50
