Direct Boxes
maggotspawn
Direct Boxes
Post by maggotspawn »
Right now I have a cheap Livewire Solutions passive direct box at the top of my signal chain.
It's so I can record dry guitar for reamping. This this thing really muddies up my tone. The dry recorded guitar sounds fine though. Is it because it's a passive di or because it's a POS? What are guys using for this situation? I have passive pickups BTW.
Re: Direct Boxes
DI's can have an affect on tone , often one is chosen for it's color . A passive DI can alter tone with long cable runs but that is kinda normal with any loading of the signal . I would guess that is just the sound of it though . But Dry signals can sound weak or like ass without a preamp . So what are you doing with that dry signal after it leaves the DI ? There are a zillion DI's out there . The Countryman is a standard . I like The Cable Factorys Lundahl DI
http://www.cablefactory.com/catalogue/C ... evices.pdf
usually anything with a Jensen in it sounds good to me . Without going into the $$$ Tube DI's you can still get great DI's for under 200 bucks . So give us your full Direct signal chain though and we'll see if we can solve the muddle tone .
Re: Direct Boxes
Radial has more choices, for passive & active, then you can shake a stick at: http://www.radialeng.com/index.php
Re: Direct Boxes
I've got the Behringer Ultra G I'm selling. It's active. LYLT and all that :D
maggotspawn
Re: Direct Boxes
My signal path is Direct Box>Tuner>Wah>OD>Noise Gate>Amp
The direct box goes into an ADA 8000>PC
The recorded tone is fine. Sound from the amp sounds brighter and more open without the DI.
BroSlinger
Re: Direct Boxes
Post by BroSlinger »
Play into a buffer before the direct box, maybe?
do you have any boss pedals you can just leave in bypass? Is your tuner buffered? You could put that before the direct box if it is.
EndTime
Re: Direct Boxes
Post by EndTime »
I just bought this radial pro Di. Passive. https://www.sweetwater.com/store/detail ... Aolq8P8HAQ
Haven't tried it , yet. So no help there. Lol
maggotspawn
Re: Direct Boxes
All my pedals are true bypass unfortunately. I think an active DI may solve my problems. May try a buffer as well.
Re: Direct Boxes
the attenuation switch could be loading it , does that affect the signal in the Parallel Out ? The Parallel Out should be totally uncolored as it's just a out right from the input .It could be a bad cable .
BroSlinger
Re: Direct Boxes
fretless wrote:It could be a bad cable .
[video]https://www.youtube.com/watch?v=OLmVTr9hq8Q[/video]
maggotspawn
Re: Direct Boxes
fretless wrote:the attenuation switch could be loading it , does that affect the signal in the Parallel Out ? The Parallel Out should be totally uncolored as it's just a out right from the input .It could be a bad cable .
Not using the attenuation switch. Cables are fine. I was told over at Gearslutz that passive DI's load passive pickups, hence tone suck.
Re: Direct Boxes
Your recorded tone "Is fine" That is using the XLR correct ? The Parallel Out is just an out , not going through any thing , unless the switch is part of the circuit . You could test that and see if it changes the Parallel Out level . If so I'd dump it if not then I don't think the DI is the problem . But it could be :D
maggotspawn
Re: Direct Boxes
Yeah, I'm recording via the XLR. I'll try the swicth.
Re: Direct Boxes
The switch should probably not affect the The Parallel Out if it does I'd say bad design and dump it , if not it's not doing anything , no loading nothing it's just a The Parallel Out to the pedals , so I'd start with that cable from the The Parallel Out to the first pedal and check it with a meter .
maggotspawn
Re: Direct Boxes
fretless wrote:The switch should probably not affect the The Parallel Out if it does I'd say bad design and dump it , if not it's not doing anything , no loading nothing it's just a The Parallel Out to the pedals , so I'd start with that cable from the The Parallel Out to the first pedal and check it with a meter .
Cables are O.K. I think this DI is just a POS.
maggotspawn
Re: Direct Boxes
Just tried the same setup with my GSP 1101. Tone suck isn't so bad, but still there a little bit.
I think I'm going to bite the bullet and get a Radial active DI for my mapz.
maggotspawn
Re: Direct Boxes
Derp. Turned out to be used error. The pad switch was set to 20db and I neglected to mention an ABY pedal before the amp. Systematically went through everything and the DI is OK. I need to try it with the pad engaged, but the ABY is a tone suck. I'm generally pretty out of it jamming after a long day and missed the simple things.
colejustesen
Re: Direct Boxes
Post by colejustesen »
If you decide to try another, the Countryman gets tons of praise!
Amps
Hughes & Kettner Duotone
Laney GH100L
Peters Halo/Hydra
Rivera Chubster 40, M100
Rocktron Vendetta 100
VHT Pittbull 100/CL
Budda 2x12 (Jensen C12K2)
Rivera K412T (Eminence CV-75)
Splawn 2x12 (Fane M65)
