Sound Treatments for a home studio 'loft'
IAmTheKurgan
Post by IAmTheKurgan »
My new house, I'm putting my studio space in the upstairs loft. Trapezoid wall/ceiling shape & symmetrical. It's longer than it is wide, and has a stairwell. There's some pretty nasty reflections in the room when I clap. What would be the best way to treat it?
AMPS/CABS:
-Peavey 5150
-Mesa Triple Crown 100
-Mesa Mark V
-Diezel DZ412S (K100s)
-VHT FatBottom 412 (P50E)
-Mesa OS 4x12 (V30s)
GUITARS:
-Jackson MIJ DK-2S
-Schecter Jeff Loomis JLX-7 'Cygnus' (Loomis Blackouts)
-Schecter Blackjack ATX V1 FR
-Epiphone Les Paul Classic
PEDALS:
-Mooer GE-300
nakedzen
Re: Sound Treatments for a home studio 'loft'
Post by nakedzen »
Does it have windows? Face the monitors along the narrower side.
Best way to find out what you need is to use a frequency generator to play 50, 60, 70, 80 Hz etc tone and walk around the room with a dB meter (a smart phone app is enough for this) in hand to find the dips and boosts. Then get bass traps meant for the frequency that's the worst in the problem areas. Those pyramid foam things get rid of the extreme high end reflections. Fill the room with carpets, heavy curtains, and diffusers and that should handle the rest. Some mid reflection panels to catch the first reflections.
Pics would be helpful.
IAmTheKurgan
AMPS/CABS:
-Peavey 5150
-Mesa Mark V
GUITARS:
-Jackson MIJ DK-2S
PEDALS:
-Mooer GE-300
nakedzen
Post by nakedzen »
Oh it's open at the other end. I'd experiment with how it sounds with the monitors at the open end vs. on the window side. You might get some benefit with the open end reducing standing waves somewhat.
Other than that you'll need to do the measurements and calculate placement yourself, any other way is just waste of money.
IAmTheKurgan
I plan to have my drum kit mic'd up and sound checked to record at a moments notice. Overheads will be ORTF. Any recommendations with that in mind?
AMPS/CABS:
-Peavey 5150
-Mesa Mark V
GUITARS:
-Jackson MIJ DK-2S
PEDALS:
-Mooer GE-300
tmcatfan
Post by tmcatfan »
Friend of mine has a loft setup. He uses detachable surfaces to deaden the room when needed, but loves the natural sound as well. I know guys with FROG setups that left the room as is. Most of these guys talked to acousticians from local colleges to help them out with placement and material options.
what is a FROG set up?
IAmTheKurgan
mamberg wrote:what is a FROG set up?
I THINK it means Full Range Of Gear??? :idk:
AMPS/CABS:
-Peavey 5150
-Mesa Mark V
GUITARS:
-Jackson MIJ DK-2S
PEDALS:
-Mooer GE-300
I would recommend covering the entire loft in tuck and roll padded leather. :D
tmcatfan
Post by tmcatfan »
Finished Room Over Garage
Well, I certainly never would have figured that out.......
Is that really a thing?
(the acronym, not the room)
audimute panels on the walls and hanging over the open part would work well.
madryan
Post by madryan »
itchyfingers wrote:I would recommend covering the entire loft in tuck and roll padded leather. :D
Naw dude...
That sparkly bass-boat vinyl stuff...
