About to record drums. Questions about rooms....
Diocide
Post by Diocide »
So I'm starting up my DIY recording of my doom project. Drumset is newly skinned, and all the pre-production is ready to go... Heres an idea of what I've done so far;
Setup all the time sigs and tempo changes in the songs
Recorded a scratch guitar track for the drummer to play along with
While it doesn't seem like much, mapping out the songs took a fucking while. Two out of the three songs we're set to record are over 10 minutes, and each one has atleast 4 time sigs, and at least a couple tempo changes. ANYWAY....
So now I'm kind of torn as to where I should record the drums. Two things I'm taking into account; room differences and setting up. The drums are currently set up in my basement, which is where I was initially planning on recording them. The other option is to bring them up stairs and track them in either my computer room, or the bedroom adjoining the computer room.
FIrst off, moving the drum set will be much easier than moving my recording setup, MUCH EASIER. But, the bedroom and/or computer room upstairs are much smaller than my basement. The upstairs rooms are about 12'x12' with hardwood floors and regular sheet rock walls. The basement is about 15'x30', with carpet floors, sheetrock walls and a suspended ceiling.
Which room do you guys think would work better for recording? If I record upstairs, I could use the one room for the drums, and the other as a "control room" of sorts, but it won't really benefit anything, because my walls are all paper thin. It would make it easier to bring the drum set upstairs, but would the smaller room "confine" or "deaden" the recording more so than the larger basement?
Any insights, and feel free to throw in anything else you think I should do before I get down to the nitty gritty... THANKS!
Re: About to record drums. Questions about rooms....
I think you will get a better sound and more available flexibility in the basement.
With a few cables - could you keep the control room upstairs?
Diocide
Post by Diocide »
Not really. If I had some sort of a snake, then maybe, but Unfortunately I do not.
JimmyPaeg
Post by JimmyPaeg »
I'd say go with the larger room
The HCAF forumite formerly known as Zeppelin Rules
[video]http://www.youtube.com/watch?v=OMT40TkgwQ8[/video]
Diocide
Post by Diocide »
I moved all my stuff into the basement and recorded down there. Did it over this past weekend. Now to get some guitars, bass and vocals on that bitch and start spamming like crazy!
tubehead
Post by tubehead »
Diocide wrote:So I'm starting up my DIY recording of my doom project. Drumset is newly skinned, and all the pre-production is ready to go... Heres an idea of what I've done so far;
Does the basement have a higher ceiling? Anyway... take the basement and treat one or two walls, but not all of them. Too bad the hardwood floors are not in the basement.
