Moderators: greatmutah , GuitarBilly
Posts: 5936 Joined: Mon Jan 21, 2013 5:10 am
Post
by Elessar [Sly] » Thu Feb 14, 2013 12:06 pm
So we recorded rough demo's of new stuff at rehearsal onto Logic, which were then copied to a 4G memory stick (as Aiff files), and when I import them onto Cubase 6 I can't get any sound when it plays, despite evidence that that it has recorded the instruments. It has been far too long since I have used a DAW
I'm not getting any signal on the mixer, but the audio file has uploaded. This is happening to normal MP3 tracks as well so it is obviously a device problem? =/
slyelessar.com Leader of the Lefties in the war against right handed facists! Laney army memberSelling: Right handed Ibanez Paul Gilbert signiture Good deals with: Cirrus, wilsoneffectsll, mr cheef, the.nameless, kpd78, Seano_Porno, jonPhillips, gjhardwick, Korgi
Posts: 17765 Joined: Mon Jan 21, 2013 9:43 am
Post
by Devin » Thu Feb 14, 2013 12:40 pm
Check the output setting on whatever track you imported the file to
Whatnow2012 wrote: try humberck piskup is bettor for metal than singlecpoil for blues
Unstrung wrote: ya it am bast
Rampage wrote: When life hands you distortion, fuck everything else.
Bauer-Burny-Dark Matter-Hamer-Ibanez-Starfield-Warwick Fryette PowerStation, Peavey 5150 2x12, Peavey VTM60, Starfield VPA-1, Sound City Master Lead 50, VVT Simo-Plex, Taurus THD450
Post
by Elessar [Sly] » Thu Feb 14, 2013 12:47 pm
Devin wrote: Check the output setting on whatever track you imported the file to
The output setting is to my interface. Unless I have set this up incorrectly, but I can record with it and playback.
Cirrus
Posts: 1352 Joined: Thu Jan 24, 2013 6:16 am
Post
by Cirrus » Thu Feb 14, 2013 1:07 pm
What are the audio files' attributes? Bit depth, sample rate?
Post
by Elessar [Sly] » Thu Feb 14, 2013 1:28 pm
Could it be to do with the control room needing to be turned off? I've read about it but I can't find out how to do it. Bit depth: 44100 Resolution: 24 bits.
Post
by Elessar [Sly] » Thu Feb 14, 2013 6:14 pm
Any help is appreciated guys
Post
by Devin » Fri Feb 15, 2013 11:18 am
Elessar [Sly] wrote: Devin wrote: Check the output setting on whatever track you imported the file to
Do you have the option to switch it to "master" instead? If so it's worth a shot
Elessar [Sly] wrote: Could it be to do with the control room needing to be turned off? I've read about it but I can't find out how to do it.
I've been using Cubase 6 since I bought my Yamaha THR10 and I honestly don't even know what the control room you're talking about is.
Post
by Elessar [Sly] » Sat Feb 16, 2013 8:54 am
Devin wrote: Elessar [Sly] wrote: Devin wrote: Check the output setting on whatever track you imported the file to
Do you have the option to switch it to "master" instead? If so it's worth a shot.
How do I do that
I'm so lost haha.
So I can record tracks and play them back, but I can't get a signal from imported audio files/tracks etc.
Post
by Devin » Sat Feb 16, 2013 12:40 pm
Elessar [Sly] wrote: Devin wrote: Elessar [Sly] wrote: Devin wrote: Check the output setting on whatever track you imported the file to
How do I do that
I'm so lost haha.
If you'd like, you can email me whatever .aiff you're trying to import and I'll see if it works on my system? peavey_impact at yahoo dot com
Micter
Posts: 302 Joined: Sat Jan 19, 2013 11:40 pm
Post
by Micter » Sat Feb 16, 2013 10:33 pm
If Cubase 6 is like the previous versions you have to set the track to play/monitor audio.
"Live clean and play dirty"
Post
by Elessar [Sly] » Sun Feb 17, 2013 5:28 pm
If you'd like, you can email me whatever .aiff you're trying to import and I'll see if it works on my system? peavey_impact at yahoo dot com[/quote]
I'd really appreciate that, but my band mates are very funny about this
. If there is any other suggestions anyone could make, please feel free!
Micter wrote: If Cubase 6 is like the previous versions you have to set the track to play/monitor audio.
This is set correctly.
Post
by Devin » Mon Feb 18, 2013 5:18 pm
Elessar [Sly] wrote: I'd really appreciate that, but my band mates are very funny about this
I don't understand....is it only ONE particular file (or set of files) that won't play, or are you having trouble playing ANY imported .aiff files?
Obviously you don't have to send me your band tracks or anything.....you could fart into the mic and email that to me and it would work all the same
If it's just the tracks they gave you on the flash drive that aren't working, something get effed up along the way to your DAW I reckon
