SLO 100 clone - Diary
am_i_evil
Re: SLO 100 clone - Diary
Post by am_i_evil »
Hello!
I finally finished my sloclone now it is time for debuging...
I made first start with a friend who knows more about amps then I do. Amp didn't blow any fuse or burn something inside it
But we noticed that the bias is not correct and we couldn't fix that with bias pot.
power amp grid = -65V
Bias measuring over 1Ohm resistor is 20mV
I belive bias is not correct I think it shoud be something arround 50mV?
I also have few hums... but this wil be on the menu later.
About Guitar Amps!
http://www.ampspecs.com
Usually more like 35 mv
Hipster Salad
Post by Hipster Salad »
Awesome thread. I think this is the first time I've seen a build where someone made their own PCB from scratch. That's just amazing to me haha. I'm anxious for the final pics and clips of this beast. One thing nabbed my curiousity - what's the reason for mounting the choke on the inside of the chassis?
Resident thread killer
I know nothing
Sterling AX40 x3
PRS SE245, SE Paul's
Jet City amps - all of them
modded 2204s
Bogner XTC 3534
Kemper rack
shep
Post by shep »
should probably check voltages and actually calculate what it should be biased at.
am_i_evil
Post by am_i_evil »
Hi, I almost finished my SLO and fix some issues with hum (just a few cosmetical work has to be done). Now it sounds great, and I love it :D
More pictures on:
http://www.ampspecs.com/myamps.php
Thank you all for help! Now I'm working on a sound clips/video...
About Guitar Amps!
am_i_evil
Post by am_i_evil »
Hello,
After few hours of joy and happiness amp suddenly lost his power. For example, if I played master volume on 9 O' clock now for the same volume I have to open my amp on full, tone also change.
The first time, when I notice this trouble I switch amp on stand and everything work ok, but few days later, trouble doesn't go away. Any ideas what to check? I double check everything again and it looks ok.
About Guitar Amps!
am_i_evil
Post by am_i_evil »
Hi,
I have some troubles with my clone, could anybody help me with these values?
Code: Select all
Pre Amp Valves
        Pin 1         Pin 2      Pin 3   Pin 4    Pin 5     Pin 6         Pin 7      Pin 8     Pin 9
V1    264          signal       2,21      3          3       179,1       signal       1,5        3
V2    259          signal       2,07      3          3       360          signal      4,3        3
V3    395          190          194       3          3       191,2       signal       1,7        3
V4    394          170          175,1     3          3       171,4       signal       2,3        3
V5    259           28          44,5      3          3       262           27,1      44,8        3
Output valves
V6   ground   3 AC   513   510   70,3   509   3 AC
V7   ground   3 AC   513   510   70,3   509   3 AC
V8   ground   3 AC   513   510   70,5   509   3 AC
V9   ground   3 AC   513   510   70,5   509   3 AC
Point voltages A B C D E F
365 374 394 509 512 -73
Fuse 1: 235V
Fuse 2: 511V
Bias : Point1 11V
Point2 12V
Thanks.
About Guitar Amps!
am_i_evil
Post by am_i_evil »
Omg... the optocouplersLDR1(VTL5C1) and LDR2 are not connected wright, + and - are turned around.
About Guitar Amps!
shep
Post by shep »
well what's the problem? if your showing only 3volts on your heaters thats totally wrong. maybe im missing something. but the heaters should be 6.3vac +/-10%
Toe-Knee
Post by Toe-Knee »
am_i_evil wrote:Omg... the optocouplersLDR1(VTL5C1) and LDR2 are not connected wright, + and - are turned around.
That will completely screw up your switching!
Also the voltage at the bias points surely thats mV? And even if so that's incredibly low
Please visit and share my guitar gear & DIY Blog
WWW.BACKLINE.TK
Toe-Knee
Post by Toe-Knee »
shep wrote:well what's the problem? if your showing only 3volts on your heaters thats totally wrong. maybe im missing something. but the heaters should be 6.3vac +/-10%
you have ~3v on either side making a total of 6.3v
WWW.BACKLINE.TK
Toe-Knee
Post by Toe-Knee »
Measure the voltage across the +/- of the LDR on either channel only 2 should show anything higher than a mV reading
On the clean channel 1 & 4 should be on getting about 2v and on the OD channel 2 & 3 should be on here's a spreadsheet with some ballpark voltages
https://www.dropbox.com/s/t28ildvzc1bub ... s.xls?dl=0
WWW.BACKLINE.TK
shep
Post by shep »
gotcha. thought that was the case. noticed the bias point voltages as well.
am_i_evil
Post by am_i_evil »
Thanks alot for quick reply!
Yes, 3v is because my instrument is not precise enough...
Yes I couldn't figure out how switching works :)
I also change trimer from 25K to 50K.
About Guitar Amps!
Toe-Knee
Post by Toe-Knee »
am_i_evil wrote:Thanks alot for quick reply!
So are you all good now then?
WWW.BACKLINE.TK
am_i_evil
Post by am_i_evil »
Don't know yet, I will try,test today/tomorrow.
About Guitar Amps!
am_i_evil
Post by am_i_evil »
Hello, I fix issue with "channels" now it looks like it works. And now I'm trying to figure out how to fix bias.
On my test points I measure 11mV an 12mV. If I understand correctly, because I have one test point for two tubes this is 22mV and 24mV per tube?
If I check site below, I need to have for my 505V, bias set to 41mV (20 per test point?)
http://www.webervst.com/tubes1/calcbias.htm
On DB102 = 2,61
Later I will check the voltages on my LDR's
About Guitar Amps!
shep
Post by shep »
i think that might be biasing it hot for the 6l6gc. on the link, if you scroll down there is a chart for biasing hot cold or average. according to the chart, average would be a bit less than 41mA. be closer to 36mA. if i understand it correctly. youd probably wanna be closer to 36mA instead.
just as a correction the measurement is in milliamps not millivolts as the bias calculator states. but i believe in your tester you will be reading the value as millivolts dropped over the 1ohm resistor. millivolts should equal milliamps over a 1ohm resistor because of this equation: r=v/i is equal to 1=v/.036 is equal to 1=.036/.036
r=resistance in ohms v=volts and i= amps
the calculator is calculating for biasing the tubes hot (70%). you'd probably wanna go with average at first, which is 60%
so, mike lx-r was correct about ~35mV
someone may correct me on this, but both test points should read ~36mV if both test point measurements are not close to one another it can mean you have an unmatched pair of tubes. :)
be careful not to turn your bias trim pot all the way down as it may overload your transformer causing it to over heat and burn out. :(
there can only be one test point per tube. i believe you are just measuring current over a 1ohm resistor at the cathode. there is only one cathode. my confusion earlier with the heaters is you can actually measure the voltage for the heaters by putting one point of the tester to one leg of the 3v supply coming from the transform and the other point of the tester to the other 3v supply leg and it will read 6.3v on your tester.
http://www.regiscoyne.com/tech/bias/
this is a good link for learning to bias your amp
am_i_evil
Post by am_i_evil »
Thank you both for helping me with this!
I measure voltages across LDRs:
Normal/clean
LDR1 1.77
LDR2 0
LDR3 0
LDR4 1.77
OD/clean
LDR1 -0.12
LDR2 1.79
LDR3 1.79
LDR4 -0.11
Normal/crunch
LDR1 1.78
LDR2 0
LDR3 0
LDR4 1.78
OD/crunch
LDR1 -0.09
LDR2 1.79
LDR3 1.79
LDR4 -0.08
Overdrive channel is a lot louder than normal channel, and it has a lot of interferences.
About Guitar Amps!
Toe-Knee
Post by Toe-Knee »
am_i_evil wrote:Thank you both for helping me with this!
Normal/clean
LDR1 1.77
LDR2 0
LDR3 0
LDR4 1.77
OD/clean
LDR1 -0.12
LDR2 1.79
LDR3 1.79
LDR4 -0.11
Normal/crunch
LDR1 1.78
LDR2 0
LDR3 0
LDR4 1.78
OD/crunch
LDR1 -0.09
LDR2 1.79
LDR3 1.79
LDR4 -0.08
They're looking about right.
The OD channel is considerably louder than the normal channel when normal is set to clean. If you set it to crunch they should be closer but there will still be a difference.
What kind of interferences are you getting? hum? hiss? static?
WWW.BACKLINE.TK
am_i_evil
Post by am_i_evil »
Just hum. And I also think that there is to much gain on overdrive channel. On 9'o clock there is enough gain for metal... But right now I'm struggling with low bias, any idea where to look?
About Guitar Amps!
Toe-Knee
Post by Toe-Knee »
I play thrash and run my gain just above that. The amp does have a lot of gain on the lead channel.
With regards to the bias double check the entire bias circuit.
Remember though that your test points are reading two valves in series per side
WWW.BACKLINE.TK
am_i_evil
Post by am_i_evil »
I fixed it, the problem was in R52 resistor. I changed it from 56K to 15K and now is biased correctly. This amp sounds :shock:
Next thing to do is cosmetic nature. I used plexi glass to make faceplate, and now I have to draw drawings on it. I'm not sure how to do this but I will have to figure it out how to transfer ink to plexi.
About Guitar Amps!
Zozobra
Post by Zozobra »
Waterslide decal paper perhaps?
shep
Post by shep »
i believe the most common way is silk screen. there are places online that will make custom silk screens. basicly,a professional form of stenciling.
