EHX Mig 50. I have to say I am VERY impressed with. It is a little confusing initially because the channels are the opposite of a Plexi, channel I is the normal channel and channel II is the bright channel. And the channels are internally jumpered.
So at first it sounded fuzzy and weird, but once I figured it out, it absolutely cranks like a 50w Plexi. Just a little less gain and a bit darker. But not a bad way. This is definitely a worthy backup for my 1987x.
But the volume taper is a lot more gradual, the plexi starts distorting at around 1.5 on the volume. This stays clean until 4 or 5, so this can be also be used as an awesome pedal platform amp. I tried to run my Carl Martin Plexitone into it and it's really close to the cranked amp tone but at a much lower volume.
This is one hell of a sleeper amp. They go for $400-600 and man they do sound really close to a Marshall Plexi, maybe with a hint of Bassman/JTM45 too. I think the confusing layout turns a lot of people off.
I will make a clip of it later today and everyone is out of the house.
