Was messing around last night with the 2 ch Recto and Uber models in Thermionik and decided to make a quick clip. How does this sound? Are the guitars too dark?
Dude ain't nothing wrong with that at all. Would be interested to hear them a little brighter but this had me headbanging inside of 3 seconds as it was.
Re: Quick clip
Posted: Thu Jan 18, 2018 10:51 pm
by Steinmetzify
Bumping this for Ex
Re: Quick clip
Posted: Fri Jan 19, 2018 1:28 am
by exafro
Thanks for the listen Stein. I'm gonna tweak a bit and post a slightly different version tomorrow. I noticed the bass was a bit too loud in my car, which I didn't hear through my monitors and headphones.
Re: Quick clip
Posted: Fri Jan 19, 2018 5:22 am
by sleewell
Sounds good. I'd try a little brighter but not much.
Recabinet 5 Ownhammer OH412 ORN + DZL V30 (Heavy hitters pack, A1 pick subfolder) High pass 100 Lo Pass 10k Lo Mid -1.9 @ 300 hz Output Volume -10 (I find Thermionik tends to clip the bus if the levels aren't brought down. I always cut volume in Recabinet, its just easier to always do it in one spot across as presets)
I bussed the Recto tracks together and then added some minor multiband compression and a Slate VTC New York( Console, Normal, Gain 1.0, Mix 100%)
Uber Chain
Vintage Driver, same settings as above.
Uber Bass 3.0 Mid 6.0 Treb 6.0 Pres 1.6 Depth off Bright off (Normal) Output -7.6 Saturation 5.0
Recabinet 5 Ownhammer OH 412 MES V30 CUT-05 Same EQ section as Recto
Bussed the Uber tracks together again with minor multiband, no other processing.
Re: Quick clip
Posted: Sat Jan 20, 2018 9:33 am
by exafro
Forgot to mention. Guitar is cheapo Jackson import with an EMG81 in the bridge. Drop C tuning
