Logic X interface help :O
Posted: Thu Oct 06, 2016 2:59 pm
by Elessar [Sly]
My interface was working fine no issues until last night. Now everything sounds miles away or muffled/ not right.
Now without the interface plugged in, the track sounds perfectly fine coming through the macbook pro's speakers. As soon as I plug in the interface - or any interface for that matter- it has this issue. At first I thought the interface was damaged, but I have other interfaces that work fine on this *different* mac pro.
I changed system preferences to the interface and logic X preferences to the interface to no avail. I can't figure out what is happening :( please can someone help?
I've used different ports, and they work fine for other things, so it isn't that. I've even got new thunderbolt cables (F you apple for silly prices!), and changed headphones, etc.
Still the same thing =`
Re: Logic X interface help :O
Posted: Thu Oct 06, 2016 3:02 pm
by JerEvil
Bad connector cable? Is there a software mix tool between the interface and Logic?
Posted: Thu Oct 06, 2016 3:05 pm
by Elessar [Sly]
JerEvil wrote:Bad connector cable? Is there a software mix tool between the interface and Logic?
I just bought a new cable because of it, same issue.
No software mix tool between the two. Also, wifi/ other things are off. Just logic X running.
Posted: Thu Oct 06, 2016 7:17 pm
by Telephant
Have you checked the Audio Midi Setup app? Applications > Utilities > Audio Midi Setup
Posted: Fri Oct 07, 2016 1:24 am
by Elessar [Sly]
Telephant wrote:Have you checked the Audio Midi Setup app? Applications > Utilities > Audio Midi Setup
Yeah I did that.
