Page 1 of 4
OK, time again for: where do you get your gain?
Posted: Thu Feb 14, 2013 12:27 pm
by draelyc
For years and years, I was an "amp only for gain" kinda guy. Didn't even like boosts so much, tbh. Certainly didn't dig running dirt pedals into a clean amp.
Welp, turns out getting a different amp, one famous for taking pedals well, changed my tune on that. I've actually gigged now with the Plexi set clean & using pedals for all my dirt ~ something I *never* thought I'd ever do!
But my current favorite set up is to have the Plexi (or whatever amp) set for low to mid gain crunch (nice, roaring growl, but not compressed & easily cleaned up from the guitar) and to use dirt boxes (either as boost or dialed to add gain from the pedal) for extra gain and for different flavoring. Seems so incredibly versatile that way, and the higher gain stuff actually sounds better that way to me now than a guitar straight into a high gain amp.
So, how do y'all do it? :)
Re: OK, time again for: where do you get your gain?
Posted: Thu Feb 14, 2013 12:31 pm
by ke2
Every way :D
I use pedals, boost the amps, boost distortion pedals with OD pedals... I have a preamp with more than enough gain.. :D
by GAS KING
pedals for now, but I prefer an amp with a dirty channel.
I've tried the cranked up amp thing, and it doesn't really jive with my style.
Posted: Thu Feb 14, 2013 12:35 pm
by Elessar [Sly]
Depends... Pedals into a clean and amp dirt.
Posted: Thu Feb 14, 2013 12:43 pm
by Marc G
my current set up is a Plexi clone set to a "dirty clean" and using different pedals to get different OD, Dist and Fuzz tones
by DISTORT6
Straight in. Well, TU-2---> NS-2 then SLO/Sig:X :love:
Posted: Thu Feb 14, 2013 12:45 pm
by 100 watt
At the moment, a semi dirty Plexi, sodomized with pedals.
EQ or Aphex Xciter thrown in at low volumes to make up for low end you dont get with the amp not being turned up
Posted: Thu Feb 14, 2013 12:51 pm
by Demiurge
I get my gains from protein and carbohydrates and fats.
Posted: Thu Feb 14, 2013 12:54 pm
by gb74
ke2 wrote:Every way :D
+1
I have 4 basic sounds at the moment that are a combination of my OD pedal and my amp's channels:
Clean - amp clean channel/pedal off
OD - amp clean channel/pedal on
High Gain Rhythm - amp drive channel/pedal off
Lead - amp drive channel/pedal on
It's a pretty simple yet versatile set up.
by 100 watt
A thing to remember when getting gain from pedals with NMV Marshalls, is your presence knob. How you set it, can make, or break your toan, IMO
Posted: Thu Feb 14, 2013 1:00 pm
by phrophus
Depends on what I'm doing, honestly. Lately, I've been using boosts into a semi-clean, slightly crunchy amp. But, every way as pointed out by ke2 would be my answer.
Posted: Thu Feb 14, 2013 1:09 pm
by sleewell
bogner fish or mako mak4
gsp1101 for fuzz and boosts
Posted: Thu Feb 14, 2013 1:12 pm
by Dave
Uhhhhh all. No overdrive pedals though.
Fuzz, amp distortion, power amp distortion, ear drum distortion, etc
Posted: Thu Feb 14, 2013 1:14 pm
by JiveTurkey
I love a great clean channel but in all seriousness have no use for one in any band I play in. I run a semi dirty clean tone (or very light crunch, either way you would like to classify it) and use my Ultimate drive pedal for leads. Or if it is something that needs more ballz in the rhythm department, I run the lead channel and hit the drive for leads in those situations. I would actually like to find a pedal that gives me a volume boost on the lead channel with just a touch of gain increase. I seem to stay at unity volume when I hit my lead channel with the dirt I have on hand. I run a 10 band in the loop at all times, so that is out for volume boosting.
Posted: Thu Feb 14, 2013 1:15 pm
by JiveTurkey
Chuck Nutz wrote:Uhhhhh all. No overdrive pedals though.
In all seriousness, I have never been a fan of poweramp distortion myself. Maybe I need to hear a good example of it?
Posted: Thu Feb 14, 2013 1:17 pm
by GAS KING
cavitation wrote:In all seriousness, I have never been a fan of poweramp distortion myself. Maybe I need to hear a good example of it?
This. or maybe I do, but don't know it.
Posted: Thu Feb 14, 2013 1:19 pm
by madrigal77
Amp only. I've never heard a pedal that I liked.
Posted: Thu Feb 14, 2013 1:21 pm
by Dave
Depends on the amp. Some just straight up aren't meant to distort.
Posted: Thu Feb 14, 2013 1:52 pm
by IAmTheKurgan
Other. I generally run a boost into the front of a medium-gain amp. Lately though, i've kinda messed around with the gain between the amp and the boost pedal more. For example, i normally ran 95% of my gain from my amp and just a slight amount of grit from my Green Rhino. Now that i have the Doomsday Device, i like the gain structure on it much more than the Green Rhino. Because of this, i'm running less gain on my amp and more gain on my Doomsday device.
I just got the Doomsday Device today though, so this could all change. The aggregate gain between the two ( OD pedal and amp channel) generally stays the same regardless of what i am doing though. its just a 'which gain do i like more' situation and i use more from that device than the other.
Posted: Thu Feb 14, 2013 2:04 pm
by Gunslinger
All of the above.
Posted: Thu Feb 14, 2013 2:05 pm
by clipless bumper
I voted other - because it depends what I'm playing at the moment.
If I'm playing the 5 watter, with 2 gain controls and a MV - it's usually all amp, and since it's 5 watts, a combination of pre and power tube distortion.
If I'm playing my JTM45 - it's pedal based.
Posted: Thu Feb 14, 2013 2:10 pm
by JiveTurkey
I also prefer 6l6s and usually those tubes are used for clean headroom purposes, unlike 34s which have a dirtier thing going on. I just got my first el34 amp (Blackstar...I know cheap sh*t lol) in a long time and I can say you definitely hear the character of the power tubes when you crank it up, diode-clipping be damned.
Posted: Thu Feb 14, 2013 2:15 pm
by Ostinato Rubato
I voted for dirty amp boosted because that's my lead tone which stands out in front of my other layers of gain. Lately since I've gotten the VH100R I'm boosting a lot less often than I used to. The amp just covers all the ground I need by itself. Out of habit and experimentation I was boosting all my channel options but that habit is dying on its own. I've just been using the BB preamp as a lead boost, which is what it excels at. :love:
Posted: Thu Feb 14, 2013 2:18 pm
by 100 watt
Ive been boosting gain a bit lately with the MXR 10 band I just aquired.
Posted: Thu Feb 14, 2013 2:20 pm
by JiveTurkey
100 watt wrote:Ive been boosting gain a bit lately with the MXR 10 band I just aquired.
10 band for me is like my bad horsie. I will never get rid of it because it is a vital piece of my rig no matter what guitar/amp combination.
