Preamp keeps on blowing fuses
Posted: Mon Feb 04, 2013 7:18 am
by NaturalBornBoy
My friend's CAE 3+SE preamp keeps on blowing fuses.
I've replaced the fuse twice and both times, the fuse blew instantly upon powering on.
What gives?
I know that in heads/combos, fuses constantly blowing is a sign that the power tubes are on the way out but what about preamps?
Re: Preamp keeps on blowing fuses
Posted: Mon Feb 04, 2013 7:50 am
by Pepi
Fast blow = Direct short. Powersupply probably. Diode/Bridge short ???
Posted: Mon Feb 04, 2013 8:02 am
by nakedzen
Does it have slow or fast blow fuses? ie. are you using the correct type?
From the manual:
100V use 1.5 amp slow blow
120V use 1.25 amp slow blow
My Mako used to blow fuses when turning on/off. Andrew told me to get higher rated fuses and it has been working just fine since. Still has the same 3 years old power tubes in it when I swapped the fuse type. ymmv.
Posted: Mon Feb 04, 2013 8:05 am
by NaturalBornBoy
nakedzen wrote:Does it have slow or fast blow fuses? ie. are you using the correct type?
0.75amp, 250v, slow blow fuse. That's what the manual states to use.
Posted: Mon Feb 04, 2013 8:26 am
by nakedzen
NaturalBornBoy wrote:0.75amp, 250v, slow blow fuse. That's what the manual states to use.
Is the voltage that comes from the wall really that high? If it's lower than 250V it'll increase the current and puts more strain on the fuse, I'd think. Try a fuse that's rated for 230V. 0.75 amps?
Posted: Mon Feb 04, 2013 8:31 am
by Pepi
Quit putting fuses in it or you will cause more damage. Take it to a tech
