gorkyporky wrote:Big John wrote:You can use a clean boost in the loop for raising the amp's overall volume and it won't change the tone of the amp if the pedal is neutral sounding. Awesome way to bring up solos if the soundman is asleep. Myself, I prefer to go the other way and use a rhythm cut pedal, then kick it off (bypassing the pot) for solos.gorkyporky wrote:...the list says that the effects loop tolerates MXR Micro Amp and the TC Booster Line Driver. Would putting that in the loop boost my overdrive channel a bit louder as well? Because when i put an overdrive in front of the amp, it just gets more gain and changes the tone, but not the volume...
So this clean boost would work even with heavily distorted channels and at high volumes? I have my volume for the overdrive channel set at about 6 during practice. Would it still work? I mean this two specific pedals, the micro amp and the line driver?
Hiya - Just rolled back a few posts and realized I missed some...
I'm the one that tried those two pedals, but it's been a while and not at high-volume. Unfortunately, my BLD died on me, so I'm not able to test that (they're a bit hard to find these days, anyway). I did try out my Micro Amp in the loop a while back, and it worked pretty well for boosting volume without adding gain - as long as I didn't crank it to the point of clipping. I've also tried out my MXR EQ in the loop, which can boost clean and/or do so on select frequencies.
I'll try to do a bit of testing at higher volume in my studio this weekend & let you know what I find.
