Page 2 of 2
Re: Vertical/angled 2x12 cab build
Posted: Sun Jul 21, 2013 10:39 am
by Dickarms
ive read the tolex one, actually. good stuff :thu:
in fact, i recalled it the other day when i saw the seam on the bottom of my orange. i was like "i remember that dude's awesome tolex tut!"
Posted: Sun Jul 21, 2013 2:09 pm
by Casey4s
Y0UNGBL00D wrote:ive read the tolex one, actually. good stuff :thu:
Cool, I'm glad it was useful to you. :hi5:
Posted: Tue Jul 23, 2013 9:15 am
by SenatorClayDavis
Y0UNGBL00D wrote:might cut my teeth on a basic 112 soon. i definitely was looking into roundover bits and a router. cant hang with the square corners.
Routed corners are definitely way nicer than square corners. And that's where the "glue and screw" method can be problematic as the screwhead could overlap where the roundover begins, so in that case you're best off to countersink the screw and use wood filler to plug the hole. Helps the screw disappear anyways so you have the option of finishing the wood or tolexing. Pretty much the same effect as the dowel method I used on the cab in this thread.
FWIW I never found tolexing that difficult. The stain/urethane thing is a much bigger pain in the ass - it literally takes days, whereas you can do a tolex job in less than an hour.
Posted: Tue Jul 23, 2013 9:22 am
by Casey4s
I usually use wood putty / filler in the counter sunk screw holes, after rounding over and a light sanding, the holes effectivly disappear for the purpose of Tolex application. Dowls work well but are overkill unless you are going to stain the cabinet. You are correct that Tolexing is not difficult at all. If you have an idea of how to get started and what materials are involved, it's pretty easy to get acceptable results.
Posted: Tue Feb 03, 2015 5:41 pm
by Tortuga
Whoa - nice job on this! Might have to use this idea!
...yea, I'm bumping old threads :D
Posted: Fri Feb 06, 2015 11:06 am
by i386
Nice cab. Something like this would do for the jack.
http://www.ebay.com/itm/round-speaker-j ... 5d52dfa231
-or-
http://www.ebay.com/itm/Speaker-jack-pl ... 3a71d2c624
Just a big washer might even work if you have the long version of the Switchcraft jack.
Posted: Tue Dec 15, 2015 8:01 pm
by clipless bumper
Bumping an old thread that was bumped bump.....
Another nice option for the roundover/screw dilemma -
Use regular screws to put the cabinet together. After the glue has set, back them out, drill, and replace them with small glued-in dowels. These can then be cut off/sanded flush, and you can roundover to your hearts content. Looks cool stained too.
