sahlomonic wrote:GRIMESPACE wrote:sahlomonic wrote:This gets me to wanting to see about modding the JCA100H for EL34s. After finally spending time with an EL34 amp after years and years with loads of 6L6 amps, I can say I prefer an EL34 base over 6L6. Mainly due to the loose character on the lower end as opposed to a tighter more articulate character I've typically found with 6L6. I'm not a djent or metal player so I don't need 'ninja lows' or anything super tight, but being more a fan of old school Marshall recordings that's more along what I like.
Did you see the stuff we've been posting above about the voicing switch? I don't have a ton of experience with EL34-based amps, but I truly believe the voicing switch that CTN and I did get us in that realm. It sounds like we're both looking for a bit more 'elasticity' and 'feel' to the sound, which I've been experiencing with that switch. A couple bux and a couple hours' work, and you may find a bit of what you're looking for. And, if you or someone ever do successfully convert over to EL34's, I'd be extremely interested in hearing the outcome. That said, I do seem to recall the Valve Queen running KT66's in her JCA, and I think FRPC was doing same. I guess that'd be good reference links to post here, eh?
Yeah FRPC has KT66 tubes in his currently, and IMO that sort of bridges the gap between 6L6 and EL34. He did a quick demo with EL34 and I thought they sounded great, but it isn't safe to run them.
With the indexing/referencing, I think that would be a great format. Example, scoop mod gets its own 'post' in the mod thread, that way you can isolate mods and jump right to it when linking to the mod. I think all relevant schems, gut shots, tutorials, etc for that specific mod should be in the same post, unless you think it would exceed the character count. I guess we would have to weigh out how many mods there are vs how much mod specific info there is.
Maybe a new sub section on the board? Sort of how RT has manufacturer specific sub sections. That might be a better solution so the amp section here isn't 'clogged' (maybe that's not the right word) with 17 Jet City threads on the front page.
If I recall, the Tung-Sol EL34B has very similar operating perameters close to that of a 6L6, so.....those may be a very close drop in and bias, but let me check into it first. Otherwise, to run EL34s, or ANY octal powertube tube for that matter, the Power Transformer would need to be changed, a few resistor/caps need to be changed and MAAAYYYYYBEE the Output Transformer. I could into some stuff and probably put together a list of changes. That way, anyone can run any tube to their hearts content, and there is the possibility of running dual bias circuits for different pairs of power tubes.
TECHNICALLY, the KT66 is not a drop in and bias replacement, but it's very close. You have to mismatch the impedance of your cab, so if you have a 16 ohm cab, plug into the 8 ohm jack on your amp, if you have an 8 ohm cab, plug into the 4 ohm jack on your amp.
What I would need from a JCA50 and JCA100 owner is to see if there is a sticker on the power transformer that gives the Volts/Amps details. I think the JCA20H has a sticker on it that says all of the ratings. I don't know if the bigger boys do. In any case, I could still find a suitable replacement if anyone is interested in doing the swap. I think I may shut down my DIY project for a spell and try to pick up a 50 or 100 to get some of these crazy mods done.
As far as the mod threads, maybe a single thread per mod in the DIY section, with a link index on the first page here. That sounds good to me.
