In response to your question, user "Pandemic 2" commented in post #456.3 (on the harmony central forums) that he was experiencing bleed through the channels after reducing the value of a cathode follower (C19 for the 50 /100, C13 on the 22h). As stated in my response I did the same mod (in addition to the scoop and many other mods as well) and didn't experience the channel bleed issue.
I have read every post on this thread and the similar JCA mod thread in Guitar Amp Board and have not heard of this issue when the scoop mod was performed.
Without being an experienced tech, which neither of us are (or we wouldnt be here on the forums for answers in the first place) here are a few logical questions to ponder regarding isolating the issue in order to identify the problem:
1) Did the issue make itself even faintly known before the mod?
2) Does the bleed come only when the scoop mod is engaged?
3) Have you tried swapping some preamp tubes around?
4) Did you leave any length of new wires (related to added/non stock/aftermarket MODs) near a transformer or B+
5) Did you leave any scraps of wire or solder on the circuit board?
6) Did you change guitars, cables and speaker cabinets?
If the answer to all of these questions is favorable and you have isolated the issue then my estimated guess based off of the simple process of elimination would be that the issue itself lies within the 470pf cap you chose. I dont know the science behind it but I do know that 470pf=.0047uf which is nearly 5 times larger than the recommended value of .001uf.
The following definition of the scoop mod is found @
http://toboy-diy.blogspot.com/2013/1...a-srv-mod.html"The mid scoop is activated by grounding a capacitor between two resistors which are bypassed by a second smaller value cap. This is called a Bridged T Filter. The top cap is usually small allowing high frequencies to the skip the filter. The lower cap is large enough to bleed off relevant frequencies but not large enough to bleed low end. Low end is attenuated as normal through the resistors. By disconnecting the cap from ground, we end up with a normal RC (Resistor Capacitor) Network. Highs skip the resistors and everything else is attenuated. The values of the components determine the effect."
Maybe there are parameters of resistance that were breeched by using a different value cap that are either allowing too much or too little signal/frequency in to the next stage due to the 470pf cap.. Just a guess. Im not a licensed tech.
This is all of the info that I can give you to help you make a better informed decision on whats causing the issue. If anyone else has something to say, please correct me and/or chime in.
