I don't worry about my nick. And cheese-bread is right. Everyone here needs a nick and this is mine.
So firstly, to ged rid of the fizz: Replace the stock tubes in the power amp with JJ EL84 and bias the amp correctly. Should be between 18 and 22 mA, I mostly prefer 19 mA. Then you could put a JJ ECC83S on V1 position. This will also smooth out a little bit of the trebly sound, the Chinese 12AX7B in the preamp produce.
For less muddy sound and tighter bottom I would suggest to reduce the first two .022 coupling caps to .01 (or even .004 on the first).
I also like a .68 as cathode bypass at V2 better than the 1u.
Increase NFB resistor to 56k (makes the amp a little more aggressive and less wooly sounding).
For darker and more vintage sound use a 56k slope resistor and 250p treble cap in the tone-stack.
You could try to increase the fizz cap from 270p to 300p or 330p - but the higher you go, the more dull the amp will sound.
If you like an overall better sound, the only way is to change all the caps to better ones. And also the preamp tubes.
