Anyone know a fix/hack for this?
MikeO
Post by MikeO »
I can't be the first person to have this happen. Anyone smarter than me know a way to salvage this case? Two of the three latches are like this.
Amps: 5150 (w/bias mod), 5150 II, PRS MT-15, FJA PV XXX, Framus Dragon, FJA PV Penta, PV Rockmaster-->Marshall 9100, PV Ultra 120
Cabs: 3 Marshall 1960B, Laney GH412, Avatar 2x15, PV XXX 4x12, Bogner OS 2x12.
Re: Anyone know a fix/hack for this?
I sorta of do, but not really.
My "fix" was to get a new hinge and install right next to the broken one. Drill the holes for it, then on the inside of the case, you need to pull out the lining a bit to access the holes from the inside. Use short screws to hold the hinge in place and tighten them from the inside with nuts and use a dab of Loctite Thread Locker to keep them in place.
For the missing/broken piece, I just tape it up with Gorilla tape. :lol:
So it's not really a fix, since the broken hinge is still broken, but it works since the case is closed with the same amount of hinges and lid is stable.
So there's another piece of brazilian engineering for you. Which is the same as redneck engineering, but brown. Good luck.
_ej_
Post by _ej_ »
GuitarBilly wrote:I sorta of do, but not really.
This is exactly what I would do but white.
Zozobra
Post by Zozobra »
Epoxy it shut.
That is Pennsylvania engineering.
MikeO
Post by MikeO »
It's not the hinges that are broken, it's the latches that hold the case shut. The hinges are on the other side, they are fine, but two of the three latches to hold the case shut were missing when I got the case (a throw in with a used guitar I bought years ago). Right now my daughter's Jackson DR3 lives in it, and she doesn't take it anywhere yet, but she will eventually.
MikeO wrote:It's not the hinges that are broken, it's the latches that hold the case shut. The hinges are on the other side, they are fine, but two of the three latches to hold the case shut were missing when I got the case (a throw in with a used guitar I bought years ago). Right now my daughter's Jackson DR3 lives in it, and she doesn't take it anywhere yet, but she will eventually.
It's still the same thing. Install a latch right next to the broken one and tape up the broken spot.
Mike Oxhuge
Post by Mike Oxhuge »
Just get new latches and drill out for bigger rivets.
Peavey XXX Head
Henning Bottle Rocket Preamp
Carvin MTS3212 Combo
80's Washburn Scavenger Bass
Boss GT1000
Mike Oxhuge
Should have typed hinges. Rivet gun kits are cheap at harbor freight, so are drills.
Peavey XXX Head
Boss GT1000
Mike Oxhuge
Also you could put tape on backside and use jb weld steel reinforced epoxy to fill holes and redrill for same size rivets.
Peavey XXX Head
Boss GT1000
primeholy
Post by primeholy »
Mike Oxhuge wrote:Should have typed hinges. Rivet gun kits are cheap at harbor freight, so are drills.
Might could grind the head off the rivets. If they are round heads could be a pain to drill
fuck
Landshark
Post by Landshark »
weld around the entire case so its completely sealed up, then cut a new access hole from the top and add new hinges
put a light inside to make it fancy
primeholy
Post by primeholy »
Landshark wrote:weld around the entire case so its completely sealed up, then cut a new access hole from the top and add new hinges
THE ONLY WAY, IS ALL THE WAY
Corey Taylor
fuck
BroSlinger
Post by BroSlinger »
Put a luggage clip strap around it.
ZEEGLER
Post by ZEEGLER »
Duh, bungee cords.
MikeO
Post by MikeO »
BroSlinger wrote:Put a luggage clip strap around it.
This is literally what I've been doing up to this point. :thu:
Anyone know where I can get latches that will fit this? The only one's I've found so far are big industrial sized latches that wouldn't fit in the area I have to work with. :bang:
Diddlybo
Post by Diddlybo »
Do you know the brand? Some brands will send out replacement parts for little to no money. I've heard of Fender sending replacement latches and hinges for free.
Amazon
These should work
https://a.co/d/dmEz6ZS
FAKA!
Post by FAKA! »
I have two old Gibson RD cases from the late 70s with messed up hinges, I use luggage straps.
GAB DrumJams - YouTube & Soundcloud
linthat22
Post by linthat22 »
https://www.fuelrocks.com/how-to-fix-a- ... ase-latch/
Saw this and thought it could help as well
MikeO
Post by MikeO »
GuitarBilly wrote:
Amazon
These should work
Rumpleforeskin wrote:https://www.fuelrocks.com/how-to-fix-a-guitar-case-latch/
Much appreciated! Thanks guys :thu:
