NinjaRaf wrote:I can see why you like the blue channel so much. It definitely has something unique going on. I still prefer the red channel clip. But I don't think one is better than the other at this point. Just different.
Blue is definitely the best channel! Haha .
GuitarBilly wrote:The 2 are very close now. The boost seems to have filled up the mids nicely.
I do like the EVH better now. Ir has more of that Marshall grind and clarity.
I have to give this pedal a try. I love what it did to both amps.
It’s a great pedal. Even I just discovered new ways to dial it. Can pretty much do anything with it the more I use. Can get it super abrasive like a Grind Pedal too. It has perhaps the widest range on a “standard “ overdrive I’ve used
I should mention both the 6505 and the blue channel were the live mics and I actually still think The PV has a brutality to it. I *Think I can dial the Evh in closer. Also on the PV clip I had to scoop out some of those Honky “wah” mids. The Evh is almost flat. So you can see basically where the differences are. The 5153 definitely scooped out those harder, more aggressive mids, kinda cleared up the low end and cleaned up the high end. So refined would be the word for sure. But PV is less perfect and sometimes that less than perfected sound is just as pleasing. But listening in my car, I would use both but I like the extra brightness of the Evh blue
