Reply to topic  [ 7 posts ]
Bugera 1960 power amp conversion
Online
As a quick aside from my rack preamp goofings off I'm converting a busted bugera 1960 a friend game me years ago into a dedicated power amp.
The OT is shot and quite convincingly failed the neon short test so it's a paper weight at best unless I ever fancy a go at rewinding it, which I don't. Thankfully I have a spare 100W 4K primary OT in my spare parts pile and the PT is good for somewhere between 480-500VDC which is premium KT88 territory for a single rail.
Design wise I'm plumping for a parallel input buffer and long tailed pair PI. It'll have a very SLO looking set of power amp controls. I may swap the presence for a 5k scratchy type and the depth for a CCV type. There is also a pot to set the amount of NFB which will control the power amp feel from tight to loose. I may also put a pot in line with the 470r LTPI bias resistor as an additional sort of MV which will allow the PI to break up at a lower volumes but this might be better suited to a switch.
The power supply will be slightly unconventional as I want to try out a regulated screen supply, rather than use the original choke feed. This has the advantage that running the screens at a rock solid 400VDC will put way less stress on the screens while still delivering full power and punch. I can also feed the LTPI straight off this node too as well as implement current limiting if there is a screen short. You'd only really notice the difference between this and the choke at super high volumes and I want a big solid bottom end which is better achieved with regulation.
Here is a quick test of the PT to check it's doing what I expect. 508VDC unloaded. More on this tonight.
Thu Sep 27, 2018 1:28 am
Cool... :thu: Did you finish it? If so, howd it go?
Sat Oct 06, 2018 6:14 pm
Online
I went on vacation : lol:
It's the first thing in doing when I get back though.
Sat Oct 06, 2018 9:46 pm
Online
Back from vacation, time to get on this. I have too many ideas to work on that need a dedicated power amp to test...
Wed Oct 17, 2018 9:31 am
Congratulations on intimidating the shit out of me!! :lol:
Wed Oct 17, 2018 10:05 am
Looking forward to watching the conversion - your build threads are awesome! :rawk:
Walt wrote:
Wed Oct 17, 2018 10:12 am
Online
Planning the bias supply and regulated screen supply layout. I just going to use the half wave bias supply that was in the Bugera and pretty much every other Marshall clone with it's own bias winding on the Px but I've decided why half arse it and will go with a full bridge.
I have somehow lost the 200V Zener diodes for the regulator though :( Yet another order to RS it is...
Wed Oct 17, 2018 11:45 am
Users browsing this forum: No registered users and 13 guests
