Reply to topic  [ 11 posts ]
HPF/LPF for guitar tracks
How do you use them on your guitar tracks? I usually HPF @ 100Hz and LPF @ 18KHz...
Rig:
Guitars: Gibson SG, Gibson Les Paul, Strat and Tele partscasters, Ibanez RG
Amps: Jet City 50H, Jet City Amelia, EVH 5150 III 50w 6L6, Marshall 1960A w greenbacks
Effects: Morley Bad Horsie, Fulltone Fat Boost 3, TC G Major.
Check out my band, The Lima Division at:
http://www.thelimadivision.com
For questions about GAB contact me at admin@guitarampboard.com
Tue Sep 25, 2018 8:32 pm
Profile WWW
I'm usually pretty close to that, starting around HP 90Hz and LP16KHZ and adjusting from there.
But, when using IRs I don't apply it to the guitar tracks in my DAW. I use the HP/LP in my AMT Pangaea instead.
Tue Sep 25, 2018 9:10 pm
Profile WWW
That’s about where I highpass/lowpass lead guitars. Rhythm I might come in a little tighter on both ends depending on how the track sounds. Also depends a bit on the bass tone for the highpass in general.
Marshall Jubilee
Loop wrote:
Tue Sep 25, 2018 9:13 pm
i dunno. it depends entirely on context, tuning, number of guitars, role in the band, and what the arrangement needs. i mean.. if you tune low, 100 hz is like 2nd octave.. in my own band the bassist tunes to e, while guits play in c. so i end up high passing at like 50-60hz. low pass.. also depends on what mic- cause i like ribbons and they roll off hard at 12k, so i leave em up top.. why filter when nothings there unless its tape?
Wed Sep 26, 2018 3:23 am
No hard and fast rules for me. But typically high pass anywhere from 75-100hz. Rarely do I lo pass.. but if I do, I come down to around 12khz. Anything above that doesn't really make much a difference to me
Slobber Rod wrote:
I got my hand stuck in my ass
Wed Sep 26, 2018 4:48 am
I go by ear. Like Newholland said all depends.
I slowly sweep until I hear the change, then I go backwards ever so slightly. It does happen to always end up between 80-100 but I typically record with the same gear.
Same for both Hi and Lo pass. Sweep until you hear the change and then bump it back slightly so you do not overdo it. I learned that on youtube :p
Wed Sep 26, 2018 6:12 am
Yeah, I am anywhere between 60-100hz. Lo Pass is "by ear" but I don't know I every go more than16 to 18 kHz. I see people go as low as 12, especially Helix guys but that always seems too much relative to how I dial in tones.
Wed Sep 26, 2018 4:02 pm
Seems like there wouldn't be much air for the guitars but what do I know.
Side note: I also found that cutting around 6k on the drums actually makes the guitar sound amazing. Try it.
Mon Oct 15, 2018 12:08 pm
Pretty much depends on the tone and the mix, but quite often I'll have the low-pass rolled down to around 8 to 10 k. But then I'll push up the upper mids and treble in the mix, quite often a high shelf into a low pass is a nice way of making things bright without being harsh.
I think if I was recording hard rock/metal I wouldn't low pass as low.
High pass... depends. Somewhere around 100, but sometimes none, sometimes 2-300hz if it's a small part in an already busy mix.
Tue Oct 16, 2018 2:48 am
long time no see.
:wave:
Spam zero at the mo
Tue Oct 16, 2018 4:45 am
neilrocks25 wrote:
long time no see.
:wave:
Haha, yeah! Hope you're good! :thu:
Tue Oct 16, 2018 5:28 am
Users browsing this forum: No registered users and 8 guests
