Reply to topic  [ 8 posts ]
Another noob question...
I have another 4x12 with 16 ohm speakers that's currently wired in series/parallel and need to make it parallel to use with a 4 ohm amp. I understand the concept of parallel wiring and how it works in a diagram but I'm having a tricky time figuring out the actual re-wiring here.
So the cab has four speakers. Each vertical pair is wired in parallel and then those pairs are connected together in series with a single wire across the bottom that bridges a positive terminal to a negative terminal. If I want to make all four speakers parallel, would I move the pos-neg bridge wire to a neg-neg position and add in another wire in a pos-pos position? Or is there more to it?
Fri Jul 27, 2018 2:41 pm
For a visual, this is how it is wired now, four 16 ohm speakers in series/parallel for a 16 ohm total load. I need to make the whole thing parallel for a 4 ohm load.
Fri Jul 27, 2018 2:52 pm
And here is what I was thinking of doing.
Fri Jul 27, 2018 2:58 pm
I just tested my theory and my multimeter is showing 4Ω (well, 3.7, but it also showed 13Ω when I tested the original series/parallel wiring, so I figured it would show just a little under 4). Just waiting to hear back if this was indeed the right way to do it.
Fri Jul 27, 2018 3:26 pm
Walt wrote:
Fri Jul 27, 2018 9:27 pm
I *think* that second one you posted looks right - especially when confirmed with the multimeter. Ajax's is a bit cleaner, but both do the job.
What are you plugging in to that needs a 4 ohm load? Old Fender?
  • CEOwLP (Sig T), Carvin DC135, Squier strat
  • DSL100H, 1960AX, Mark III, homebrew 2x12 (C90 / EVM12L Thiele), '73 Fender Pro Reverb, POD HD500X (Church rig), JCA50H
  • PLX GABion, Crybaby, Small Clone, DL8, MXR108, Algal clone, Pharaoh (thanks Greg :bow:)
Help out MISTER NOBODY: https://www.gofundme.com/34f76sf4
Sat Jul 28, 2018 4:39 pm
You realize......solid state amps don't give a shit, you can do what you want, it'll never blow up
Sun Jul 29, 2018 10:23 am
You are good, 4, 8 & 16 ohms are rounded values. The 3.7 ohm would round off to the 4 ohms you were shooting for.
Amps: 5150 (w/bias mod), 5150 II, EVH 5150 III 50 watt, FJA PV XXX, Framus Dragon, FJA PV Penta, Marshall 9100, PV Ultra 120, GK 2100 SEL
Cabs: Mesa Recto 4x12, 3 Marshall 1960B, Marshall 1966B, Avatar 2x15, Mesa Recto 1x12, misc 2x12's.
Sun Jul 29, 2018 2:28 pm
Users browsing this forum: Google Adsense [Bot] and 3 guests
