Reply to topic  [ 59 posts ]  Go to page 1, 2  Next
Looking into drum vsti, EZDRUMMER sucks
Author Message
What should i be checking out? I want to record songs and i have no way of getting decent drums except programming, so far i have been programming drums in guitar pro and using ezdrummer, but this method yields mediocre results. What vstis should i be checking out and is there a better way to program drums? thanks!
https://soundcloud.com/chris-mccreight
Tue Mar 12, 2013 1:34 pm
Profile
Get some other midi packs for Toontrack for realistic programming. Edit the grooves for your particular section if you need to.
Andy Sneap's Metal Machine is a great EZX for heavy shit.
What is it that you dont like about your drums?
Tue Mar 12, 2013 1:53 pm
Profile
i have dkfh and it sounds like.... shit haha the snares all sound like garbage and the toms sound like shit and.... basically the entire kit sounds like garbage to me.
Tue Mar 12, 2013 2:00 pm
Profile
Get the Metal Machine expansion pack. It sounds WAAAAAAAAAYYYY better than DFH.
Guitars: Ibanez RG752 Prestige 7 string, Ibanez RG7420 7 string, Tokai Goldstar Strat copy, Squier Stagemaster Floyd Rose
Amps: Randall RM100, Randall RVC combo, Marshall 1960B with Hellatone 30s.
Pedals: Boss TU-2, Dunlop 535Q wah, MXR Phase 90, Maxon OD808, Boss NS-2, TC Electronic Corona Chorus, TC Electronic Flashback X4 Delay, TC Electronic Spark Mini
Dave wrote:
setting the bar lower, so I always look better. WITHOUT EVEN TRYING
Thanks Juggalos/Juggalettes/ICP, you da real MVP
Tue Mar 12, 2013 2:20 pm
Profile
Thats because DKFH sounds like shit.
Profile
ok ill try that. how about the problem of programming? is guitar pro viable?
Tue Mar 12, 2013 2:22 pm
Profile
I dont know about guitar pro...but I already gave you what I think is the best way to do it. get the midi files that good drummers actually played in an E kit.
Tue Mar 12, 2013 2:24 pm
Profile
GABmiral
get all their midi packs , it's way easier to go in and tweak a few beats then it is to write a few bars .
Tue Mar 12, 2013 2:25 pm
Profile
i am afraid i dont know what midi packs are since i have only used guitar pro... how do i do this?
Tue Mar 12, 2013 2:27 pm
Profile
you dont know what midi is?
Tue Mar 12, 2013 2:28 pm
Profile
i dont know really, all i know how to do is make shit in guitar pro and export as midi... :lol:
maybe you have an article i can read or something?
Tue Mar 12, 2013 2:31 pm
Profile
GABmiral
EZ comes with some drag and drop beats have you used those ?
http://www.toontrack.com/products.asp#MIDIPacks
scroll down to midi packs
Tue Mar 12, 2013 2:33 pm
Profile
what the fuck
listen...
Open up your DAW, load EZdrummer as an instrument. Look in the "groove" section in the plug in, and audition some of the grooves. If you find one you like, drag it into the track. Do that until you have a song. The things that you drag are midi files. Double click them to see the MIDI editor in your daw, and play around with the notes to change the beat.
Tue Mar 12, 2013 2:35 pm
Profile
well... ill be trying this later on haha. thanks dudes, i hadnt messed around with any of that.
Tue Mar 12, 2013 2:37 pm
Profile
This could be abit too advanced for op yet, but I simply replace all the drums in ezdrummer with aptrigga.
http://www.apulsoft.ch/aptrigga/
It's a very good drum trigger plugin, and it's cheap. Free drum samples are all over the net, you can find a ton from the Andy Sneap forums alone. In the long run it comes off a lot cheaper than buying kits.
Here's a start:
http://www.ultimatemetal.com/forum/f-o-h/311618-drum-samples-meta.html
http://coraxo.space
Tue Mar 12, 2013 10:48 pm
Profile
Metal Machine, no question.
Randall V2 + RS412XLT100
Tech 21 Midi Mouse, Alesis Midiverb III
Schecter Omen, OLP MM5 bass
Other: Randall Titan, Proamp Viper 112, Amptweaker Tight Metal
Tue Mar 12, 2013 11:54 pm
Profile WWW
Ive been pretty happy with Slate drums
Wed Mar 13, 2013 4:46 am
Profile
I have a feeling it's your mixing skills rather than EZDrummer that's to blame. Try working on those before you go buying something else. I used EZD with the stock kit for years and had great results. Like this clip:
http://tonefinder.com/?section=id&value=5671
Post a clip of what you're getting.
Wed Mar 13, 2013 5:46 am
Profile
EZD isn't the best, but it can sound pretty good if you know what you're doing.
From the sounds of it though, you haven't got a clue what you're doing. :idk:
Good drum programming takes a lot of time and attention to detail, even with the best drum samples. Great quality sampling doesn't suddenly make up for half-arsed programming. And then you've also gotta be able to mix well.
All the money in the world couldn't get me programming drum tracks in Guitar Pro.
Unless you're blending the samples, what's the point of running EZD just to use for triggering other samples? You're already programming in MIDI, so why not just load your samples up in whatever sampler (e.g. Battery) and go straight off the MIDI track? Seems just a waste of system resources. :idk:
Wed Mar 13, 2013 6:12 am
Profile
Yeah there are lots of great clips using EZD, and DKFH.
I thought it was funny to see "EZDRUMMER sucks" and then he doesn't even know how to use the plugin :lol:
Anyway, Id also like to hear an example of your recordings.
Metal Machine sounds the shit without having to do much of anything to it though
Wed Mar 13, 2013 6:16 am
Profile
That probably would be a better way. I've just never had any problems with this setup, and I'm still using the cymbals from ez. Any free samplers that are good? Battery seems too hiphop/electro oriented. (And expensive)
http://coraxo.space
Wed Mar 13, 2013 6:22 am
Profile
This is really cool to use with EZDrummer: http://www.rayzoon.com/. I've had it for a month or so and have barely scratched what it can do. I bought the cheapest one they had since I'm using EZD with it. Here's the blurb from the site:
This ground-breaking virtual drummer VSTi runs synchronized with your sequencer and features in-depth real-time modeling of various styles as well as human drummers with their own habits, accents and fill characteristics. Together, they can create thousands and thousands of realistic drum performances, each one editable down to the last hit thanks to the built-in limb-centric bar editor.
This unrivaled drum simulation is complemented by a high-quality sample player with up to 4GB of samples (Studio version) but can also MIDI-drive your favorite drum module with the brain power and arrangement functionality of Jamstix.
Did we mention it can jam interactively with your MIDI or audio input? Make sure to download the demo and prepare to be amazed...
Wed Mar 13, 2013 7:11 am
Profile
GABmiral
Dude go here:
http://www.groovemonkee.com/en/products
Then get Steven Slate Drums EX4
Any DAW (Reaper, Logic, Cubase, etc.) will allow you to create a track that you can drag and drop the midi files from Groove Monkee on. THen you apply Slae and viola!
It's really easy. It way more intimidating to try than it is actually doing.
EDIT:
Checked out that rayzoon thing. I would suggest learning the standard piano roll in your DAW. Just my $.02
https://www.facebook.com/dunkysndemos
Wed Mar 13, 2013 9:34 am
Profile
Programming drums in piano roll is do easy once you learn all the shortcuts and hotkeys.
Wed Mar 13, 2013 9:43 am
Profile
ok I am a noob, not a retard :lol: I can hear dkfh and the snares sound like shit, always.
Anyways, I am using reaper, so I am gonna check out these suggestions. Thanks!
Wed Mar 13, 2013 10:54 am
Profile
the drums are super quiet in this clip. I'll post something later on for an example.
I also want to add i dont know a lot about mixing either, so you are correct in that assumption as well.
Wed Mar 13, 2013 10:58 am
Profile
http://tonefinder.com/?section=id&value=12517
Wed Mar 13, 2013 11:28 am
Profile
GABmiral
Picked up EZ Drummer from Loop on Black Friday for $30, but I have't sat down and tried to learn it. Any tips?
  • CEOwLP (Sig T), Carvin DC135, Squier strat
  • DSL100H, 1960AX, Mark III, homebrew 2x12 (C90 / EVM12L Thiele), '73 Fender Pro Reverb, POD HD500X (Church rig), JCA50H
  • PLX GABion, Crybaby, Small Clone, DL8, MXR108, Algal clone, Pharaoh (thanks Greg :bow:)
Help out MISTER NOBODY: https://www.gofundme.com/34f76sf4
Wed Mar 13, 2013 12:33 pm
Profile
Dont ask me :lol: i didnt know shit about the program. There is some good tips in here though.
Wed Mar 13, 2013 12:37 pm
Profile
Here's a tip:
Open it up and play with it.
Its easy enough that a downy retard could use it.
Wtf is wrong with you people :lol:
Wed Mar 13, 2013 1:08 pm
Profile
GABmiral
Sorry - probably was a dumb question... will read later and get motivated
Wed Mar 13, 2013 1:09 pm
Profile
Ok, yeah it sucks...but is because you dont know how to mix...
Wed Mar 13, 2013 1:14 pm
Profile
:idk: that clip doesnt even sound that bad. Overdrivens drums arent even audible so that isnt a real good example either (no offense meant)
Wed Mar 13, 2013 1:23 pm
Profile
maybe you can post a clip rear naked? since you seem to be the expert ;)
Wed Mar 13, 2013 1:25 pm
Profile
My shit pretty much sucks but it is because I suck at mixing too
:dance: :dance: :dance:
Was that DKFH or regular ezd kit?
Wed Mar 13, 2013 1:28 pm
Profile
:lol: mixing.... how does it work
it was the regular kit. trust me, every time i try to use dkfh the snare is putrid and ill be damned if its my mixing.
Wed Mar 13, 2013 1:33 pm
Profile
Do you try to fix the snare?
Wed Mar 13, 2013 1:48 pm
Profile
fix it? idk haha
ok im having another problem. the "grooves" i try and drag and put in reaper are coming up with a failed to import message. halp?
Wed Mar 13, 2013 1:52 pm
Profile
Holy-diver wrote:
fix it? idk haha
Fix it = EQ, compress, make it not sound like shit.....MIXING lol
umm...make sure the midi files are stored in the right spot. Are they playing at all? If they are playing in the GUI when you hit play, i have no idea what would be wrong. Sounds like you have a problem with your cracked version :D
Wed Mar 13, 2013 1:55 pm
Profile
naw man, they are normal and playing and everything, and they sound cool, but it fails to import.
Wed Mar 13, 2013 1:57 pm
Profile
I recorded this with EZ Drummer Metal machine, Drums are buried but not bad, Use my FJA Modded JSX!!
http://www.soundclick.com/bands/default ... dID=417483
Wed Mar 13, 2013 3:39 pm
Profile
What it basically sounds like is someone exporting a drum track from Guitar Pro (which are usually shit to begin with), and just running the MIDI track into EZD. No tweaking of the drum track, no discernible attempt at mixing, no shits given. :idk:
If you want to apply minimal effort in mixing, maybe look at the EZ Mix products. Pretty sure they just released a new drum related one (or at least I got an email about one the other day). Then there is the matter of the quality of the sequence. If you want real sounding drums, part of it is the sample set and how it's triggered, part of it is the quality of the sequence. If you can't be arsed programming properly (I dunno how good Reaper's MIDI sequencing is, but Guitar Pro won't cut it), that's what the MIDI packs are there. They've got all kinds of shit in all kinds of styles played by real drummers on e-kits, and from memory they're cheap as shit.
Otherwise, you've got a lot of learning to do, both in sequencing and mixing.
Wed Mar 13, 2013 4:10 pm
Profile
Sounds like your velocity is set really low.
I like Metal Foundry.
Wed Mar 13, 2013 5:06 pm
Profile
http://dl.dropbox.com/u/1109082/tallica.mp3
:cop:
Thats ezdrummer stock kit
the kick drum didnt work out too well for me :o :cry:
Wed Mar 13, 2013 6:35 pm
Profile
Thats just what it sounds like on hard hits
Wed Mar 13, 2013 7:12 pm
Profile
did you just record that really quick :lol:
it sounds better than mine. I am trying to get the drag and drop MIDI to work now
Wed Mar 13, 2013 7:24 pm
Profile
I figured it out, you have to run reaper as admin and it works... cool :D
so now what is piano roll?
Wed Mar 13, 2013 7:26 pm
Profile
double click the midi file once you drug it in. This will take you to piano roll
if you cant get them to drag in from EZD, just go find where they are kept and drag them in yourself and play with it that way.
Wed Mar 13, 2013 7:42 pm
Profile
Took me a while to mix it, since I wanted to use that shitty EZD kit to show you what you can do with it if you fuck with it.
I learned a lot tonight trying to make it sound good lol
Wed Mar 13, 2013 7:44 pm
Profile
Where did you get the backing midi for the drums?
Wed Mar 13, 2013 7:58 pm
Profile
Who is online
Users browsing this forum: Bing [Bot], Bonano, bubbastain, crankyrayhanky, GoldstarGuitar, Google [Bot], Google Adsense [Bot], iff, jonpall0210, LukeBurke1, Mochi, Speedbump, Texsunburst59, Toshiro, trey85stang2, zarc and 137 guests
Search for:
Jump to:
