Reply to topic  [ 3 posts ]
Ground Loop, Ground lift question
Author Message
Given this circuit for my load box/line out, where would you place a ground lift to eliminate 60-cycle hum from a ground loop?
Thanks !
sound clip: http://www.tonefinder.com/files/841504978622-wiygn2.mp3
"This thread is weird."
Fri Dec 23, 2016 5:01 am
Profile
edit: Sorted this out. Removed chassis ground (B in above schematic).
This isolates the secondary side of the audio transformer from the chassis ground on the primary side. Thereby isolating it from the 100W tube amp's ground potential - thereby eliminating the 60-cycle hum.
Able to run the amp on 8 for twenty minutes with heat sink and power resistors merely getting warm to the touch, not hot.
Very transparent! Quite amazing, really. It basically sounds like the amp would if I were standing outside my house and running the amp on master vol 8 - only at bedroom levels.
Tone is there. Saturated, warm, crunchy sustain, organic feedback at low volume. :beavis:
Sat Dec 24, 2016 8:51 am
Profile
Made one final change to the circuit. Changed the wire from the volume pot to the line out jack to a shielded cable. Connected shield to audio ground. Even less prone to noise even at high (amp) volumes.
Sound Clip:
http://www.tonefinder.com/?section=id&value=16763
Sun Dec 25, 2016 4:12 pm
Profile
Who is online
Users browsing this forum: No registered users and 8 guests
Search for:
Jump to:
